Tomsoffroad & Customs
Vendors selling all suspension components from shackles to Shocks.
Moderator: Vendors
tomsoffroad
Flopsie
Re: Tomsoffroad & Customs
Post by tomsoffroad »
jonossiksilvia wrote:did ya run the latest surf up the ramp? if so pics?
Not yet. The front is getting done as soon as I finish this cage. 12" FOA coilovers going up front.
tomsoffroad
Flopsie
This is the first stage of the bar work which is going into this truck :mrgreen:
imsohi
Post by imsohi »
Nice Bar work built like a brick SH*T house :lol:
niblik
Post by niblik »
Is there any bracing to go between the two upper rear corners chap? Once ya get a lean onto something, the sides may bow in slightly? Also, the void between the bars in the rear quarters, by where ya logo sticker is, could be susceptible to mischief? I know it's better than nothing, just wondering.
Clean form with nice aesthetics nigs. Likey.
tomsoffroad
Flopsie
niblik wrote:Is there any bracing to go between the two upper rear corners chap? Once ya get a lean onto something, the sides may bow in slightly? Also, the void between the bars in the rear quarters, by where ya logo sticker is, could be susceptible to mischief? I know it's better than nothing, just wondering.
:mrgreen: :mrgreen: :mrgreen: Its getting the full exo treatment fulla.
I think the rear quarters will be fine. There's always a chance that a wayward branch or rock may get in there but short of iron cladding it.....
wjw
Post by wjw »
tomsoffroad wrote:iron cladding it.....
hmmmm
Who knew Prados could fly?
Roenut
Post by Roenut »
love the GQ airbox back on page 57 :D
would that also restrict small amounts of water getting through the filter as it sits off the bottom of the box?
love checkin out your work mate
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
Twodiffs
Post by Twodiffs »
Roenut wrote:love the GQ airbox back on page 57 :D
Same :mrgreen: . It might be on my to do list to get the passenger battery switched over to the drivers side...then new airbox and snorkel.
tomsoffroad
Flopsie
Thanks.
Well nothing really. Id imagine a small amount would get sucked through the filter. It's pretty easy to monitor through the Perspex lid.
Much the same as any other snorkel set up.
That truck is back in this week for some barwork so Im keen to have a look and get some feed back from the owner as I haven't seen it since I did the job. :D
Roenut
Post by Roenut »
Thanks.
Thought it was a sweet concept, much more practical than being stuck on some skyline cruising around the aves. I'm almost sold on you making one for my new surf....... :roll:
tomsoffroad
Flopsie
Got the 3 link front all done. (owner is pulling it apart and painting and re-assembling) I'll try flex it today but this one should be reasonably extreme :mrgreen: :mrgreen:
Coilover top mounts. The driver side one got a notch in it to clear the steering column
Panhard, coilover and bottom link mounts
Panhard mount
Hmm, shame its only got 12" coilovers :mrgreen:
Panhard is made from 30mm hollow bar
Next one the list if front and rear bar work on a GQ Safari...................
rokhound
Post by rokhound »
What's the guts on certing it with a 3 link Tom? Heard that was going to be an issue (and has been an issue in the past).
tomsoffroad
Flopsie
rokhound wrote:What's the guts on certing it with a 3 link Tom? Heard that was going to be an issue (and has been an issue in the past).
Yip there was an issue. The 3 link which I originally did on Sams Surf would've been fine if the top link was on top of the diff head apparently, but I put that one on the passenger side :roll: Jeremy's Navara has a certed front 3 link. Time will tell :mrgreen:
tomsoffroad
Flopsie
Wasn't able to run it up the ramp :cry: It probably has a bit more flex in it.
rob-mu
Post by rob-mu »
Very nice as allways Tom.June just seems so far away :cry:
tomsoffroad
Flopsie
Safari front bar with pto winch :D Rear bar under construction....................
tomsoffroad
Flopsie
tomsoffroad
Flopsie
De-Ranged
Post by De-Ranged »
Nice, bit of work in that one
Just out of curiosity whats the bump on pass side for ?
tomsoffroad
Flopsie
De-Ranged wrote:Nice, bit of work in that one
Cheers Dude :D Its for the pto drive. The hole is for the oil drain bung. :wink:
nz_bundy
Newbie
Newbie
Post by nz_bundy »
Was wondering what size tube you used for the link arms on that surf?
tomsoffroad
Flopsie
nz_bundy wrote:Was wondering what size tube you used for the link arms on that surf?
1 1/4" heavy wall nominal bore pipe.
Cheers Tom
tomsoffroad
Flopsie
tomsoffroad
Flopsie
T-mo
Post by T-mo »
That GQ PTO bar looks awesome. your not in the market of blueprints too are you? I'm looking at building something similar shortly.
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
Taz
Post by Taz »
Purrrrrrrrrdy :mrgreen:
tomsoffroad
Flopsie
T-mo wrote:That GQ PTO bar looks awesome. your not in the market of blueprints too are you? I'm looking at building something similar shortly.
No not really sorry. I do have the templates for the up-rights but the rest sort of just happens on the day :mrgreen: Freights no problems if you wanted me to build you a bar tho?
Cheers :D
Batfastard
Dr. Love Glove
Post by Batfastard »
That spare wheel mount looks mint tom
tomsoffroad
Flopsie
Batfastard wrote:That spare wheel mount looks mint tom
Thanks :D
Here's another snorkel. Exo started too :mrgreen:
tomsoffroad
Flopsie
Exo is coming together, well actually its finished :mrgreen: Will be welding it to the truck tomorrow morning :wink:
Might have gotten carried away with gussets :roll:
Return to “Suspension”
