Anyone got a stuffed old winch I can beg, buy or beer swap parts off. I've got an old GEW10000 cheapie that I just pulled down for some TLC. The plastic bush from one end of the drum is torn up. Its 63mm ID, 66.5 OD, 12mm wide, 5mm lip. Don't know if that's a standard size or a one off.
I tried a couple of bearing shops. One web site thought it might have been a warn copy, went through some parts books in Fully Equiped but nothing had sizes and they had no stock to compare. Eng Plastics or Mulford Plastic can spin one up for $100 which is ouch for a $3 bit of plastic but worth it to save a $500 winch I guess.
Suggestions?
WTD Winch drum plastic bush
- drive it ...
Re: WTD Winch drum plastic bush
seal imports ltd,??????????
29 Nga Mahi Rd Sockburn 8042
03-341 8043
03-341 8043
- drive it ...
Cheers, worth a drive past.
- mudlva
what about a brass bush turn down to suit. will last a heap better than plastic
If it is a Runva winch, Mike at www.winch.co.nz should be able to source it as a Runva spare part.
Not always, depends on the plastic and the lubrication, there are a number of very good bearing "plastics" that will perform better than brass especially if the lubrication is marginal.
If Runva can't help i could do one in Vesconite. Will be a little bit more than $3 though.
Tim
Its not this is it
Measures 63mm there abouts internally.. about 65 externally
Shit you can have the whole winch I got for bits if ya interested minus the motor.. I didnt get that bit..
This is what I got
This is what I got
- drive it ...
Bingo - that's the part. Mines a 10000 not 9000 but looks same, probably just diff gears.
You're in QT right? Coming up to Chch anytime soon?
PM me what you want for it, might get you to post up the bush and we'll sort out catching up on the heavy bit somewhere.
Stoked
Go ORE
Steve
Stoked
Go ORE
Steve
Cool i'll try Mudslinger as he is coming doiwn here all the time..
so he may be able to get it to you..
