How to tell
RoloverRover
How to tell
Post by RoloverRover »
How do you tell the difference between a series2a box and a series2a sufix b box? and between a series2a and a series 3 any help would be appreciated on this as i have just had 2 change my series3 box out becuase of a blown reverse and i have put in a series 2a or at least i think it is a 2a im not sure.
Dunno but about 20 years ago I had a late 2A (with the lights in the guards) and swapped the gearbox with a 1950's or early 1960's seires 2 landy. It was a straight bolt in job, I don't recall any problems with it?
gomulletgo
Post by gomulletgo »
Could be talking sh!te here (I know nothing of landys)
But I heard that series 1and2 had no syncros where as series 3 did. don't know whether that helps you or not.
MULLET :)
turoa
Pyro Junior
Post by turoa »
series 3 has syncro on all gears. 2a boxes are apparently the strongest, and only have syncro on 3rd and 4th???
RoloverRover
Yes the 3 had syncro on 2nd up the 2 has syncro on 3rd&4th only but with 2a and the2a suffix b is their any markings or tell tail sign on the outside of the box? I am finnishing puting the 2a box in today i did find their was a difference in the bell housings the 3 has a diff clutch setup so we had to swap the bells over but im still not sure if it is a 2a or a 2a suffix b
mercutio
Post by mercutio »
best place for a answer to this question is probably the yahoo nzlroc group
they can tell you anything about absolutely any landrover ever built right down to the size bullets you should be using on your wiring loom in your series 1
if you ask me some of them are a little bit obssessed
