Wheel hitting radius arm
For all Nissan related topics
tafftunk
Post by tafftunk »
Probably a dumb question new to all this nissan stuff but my drivers side tyre rubs on my radius arm on my gq safari on full lock only on that side not the passenger side I have a 60mm lift and 35s with front and rear guard chop and this is the only place I get tyre rub any help would be awesome thanks
jonossiksilvia
Re: Wheel hitting radius arm
Post by jonossiksilvia »
just adjust the steering stop on that wheel slightly until it stops rubing
Twodiffs
Post by Twodiffs »
Yep...plus check the steering stop bolt is still there, they are known to come loose and fall out. If so a good hex bolt will work as replacement with a locking nut for adjustment.
tafftunk
Post by tafftunk »
Oh sweet cheers guys thats awesome now to attack the dreaded long bolt on the thermostat, the water temp needle is only just above the cold mark thermostat must be stuck open hope that's the only problem and pray to the nissan gods the long bolt comes out as one piece wish me luck
klompy
Post by klompy »
I found on mine with 35s they are just to fat and need a different off set rim to move the whole tyre/wheel thing out a bit.
tafftunk
Post by tafftunk »
I've got -22 offset rims and its only hitting on the drivers side had a look for the little stoppers but can't see them or weather there was any there in the first place
motardbiker
Post by motardbiker »
tafftunk wrote:...... now to attack the dreaded long bolt on the thermostat......
Give the head of the bolt a few good hits with a small hammer, if you cant get a clean hit on the head of the bolt, use a pin punch, this will usually 'shock' the threads and loosen the rust and crap etc
tafftunk
Post by tafftunk »
Cool thanks for that it worked a treat massive and the truck works mint with a new thermostat, Now to replace panhard bushs then the truck is ready for hammering some mud
Return to “Nissan”
