Ok so my engine has a rattle to it even after doing the lifters. Seems to be lacking power as well.
Some times it will stop its rattle and gain power.....
Worn lifters? Or worn push rods?
I was thinking that it could be a worn point on the push rod head and when it spins/rattles around to another point it might take up the space and stop the rattle, which in turn could make the valves open the right distance and gain power.
What are my options as I have a trip coming up that I want the 4wd sorted for.
Weird problem?.. D21
Re: Weird problem?.. D21
Cam lobes? A lot of older Nissans had issues with shite quality cams....
check timing gear and chain also , have you checked to see how much oil pressure it has , ?
Presuming you got td27? Rocker shafts can wear. Need to remove rocker assembly and check the underside (load side) for wear. (sometimes sliding rockers down shaft is enough to check)
Yep checked chain and rocker gear already.
If it is the cam shaft can I get it re ground??
try putting that stuff in that says it will stop ratterling tappets and lifters then youll know if it does but it only lasts a little while
BogBoy wrote:Yep checked chain and rocker gear already.
As far as I know (which isn't very), chuck it out and put a new one in (if that is the issue)
philip121 wrote:try putting that stuff in that says it will stop ratterling tappets and lifters then youll know if it does but it only lasts a little while
I use promar but only in petrol engines....
rokhound wrote:BogBoy wrote:Yep checked chain and rocker gear already.
Sweet I was just thinking if you got one repaired it shouldn't do it again?.....
