As per tittle
Wanted a SJ413 or Samurai transfer Case
Any condition considered , wanted for rebuild .
WTD : Suzuki SJ Transfer Case
LR110 ..... LJ50 project
Re: WTD : Suzuki SJ Transfer Case
what bits you after chirs, i have the casing and some gears from when i wrecked one to build my rocklobster
I'm after the 56 tooth high gear off the main output shaft .
A spare main shaft would be good too , just incase my 410 case is more worn than expected
I have a sj413 case if your interested? Unknown condition but selects gears fine. If your interested just pm me. Cheers
bump .
still looking , anything considered .
- Rotazuk
If I pull finger and pick up my t/case from Rex I may have one here . Will have to do a ratio count first to make sure I don't want it . Pm me an offer .
