auto box shaft seal
brakes-shocks-lockers-etc
wildplumdx
auto box shaft seal
Post by wildplumdx »
just removed the engine out of a 92 2.5 pajero last night and was wondering if its a good idea since the engines out to replace the seal where the engine shaft goes into the trans box ? i mean it wasn't leaking but while the engines out ?
Big
Re: auto box shaft seal
Post by Big »
I'd say if it not leaking then don't remove it as if you do then you could be in for more trouble.. They only get replaced when they leak.. :wink:
kbushnz
Post by kbushnz »
My vote is to change it while you are in there...
Do the trans input seal....And also if that particular engine has rear crankshaft seal issues / leaks do it also....
