Radius bushes, which ones to use?
For all Nissan related topics
Gren
Post by Gren »
Hey guys I'm about to replace the radius/diff bushes in the front of my y60 safari.
It's only used to pull the boat and my fat ass to work so my question is do I go genuine or aftermarket and is there anyone you recommend to purchase these from?
Cheers all
Re: Radius bushes, which ones to use?
Standard ones are best after are soft and will not give the standard feel your used to
But are not cheap off Nissan over here
Gren
Post by Gren »
Hmmm righto off to get bent over then......
nismo26
Post by nismo26 »
Get the Toyota ones off Suzolla cheaper than Nissan and still fit, don't get the cheap ones they #### out real quick,
Gren
Post by Gren »
???? Toyota ones? Same same?
nismo26
Post by nismo26 »
Yep Toyota ones, pm Suzolla I got some off him for my Safari.
Filthy4x4
Post by Filthy4x4 »
80 Series Landcruiser ones are the same I beleive. Dont get Nolathane either, doesnt last long...
027 MUD GEAR - (027 683 4327)
Check our facebook:
nismo26
Post by nismo26 »
Gren
Post by Gren »
Ahhaa awesome!!
suzolla
Post by suzolla »
Thanks for that nismo.
Gren, yes still got some.
Tim
Gren
Post by Gren »
Cheers Suzolla.
Hey while you're all here, anyone had those caster adjusting bearings put in their trucks?
I'm determined to get this thing driving straight and have seen these things mentioned a few times on the Aussie site.
DaveM
Post by DaveM »
Do you have a problem with the castor at the moment?
Gren
Post by Gren »
Yeh it is set back 1 degree on the left.
Return to “Nissan”
