my jeep project finally got the parts coming
What you guys think
1 XJ 6.5" Front Coil Springs
XJ / ZJ Coil Spring Isolator, pair
Fixed front upper control arm (XJ 3-6.5"), pair
Heavy Duty Fixed Lower Control Arm With Bend, XJ3-6.5"
Heavy Duty Coil Spring Retainer for XJ, ZJ, TJ
Heavy Duty Over The Knuckle Steering RIGHT HAND DRIVE
XJ Drop Pitman Arm
Hack 'n Tap Slip Yoke Eliminator Kit - NEW DRIVESHAFT
tools 1 drill bits and tap required for installation of SYE kit
Hack N Tap Drill Jig - 27 spline
XJ/ZJ Adjustable Double Shear Track Bar Kit RIGHT HAND DRIVE
Tenneco Heavy Duty Steering Stabilizer (XJ/ZJ/TJ)
Alloy USA Yoke Conversion Kit Dana 35
1x Alloy USA Yoke Conversion Kit Dana 30
2x Caliper Repair Kit Front TJ,XJ,ZJ
XJ Drop Pitman Arm
Re: my jeep project finally got the parts coming
4x4part wrote:What you guys think
XJ Drop Pitman Arm
Quite a set up. But leave a lot of unanswered questions.
What size tyres you planning on running on the XJ? Are you planning on keeping it road legal? Have you cut the guards for wheel clearance? Any plans on changing the C&P ratios?
33 inch tires.
bushwhacker fender flare all ready fited.
i have a ARB diff locker for the Dana 30
i will be putting it in when i get the c&p ratios for front and rear.
im also looking at getting a sert for the road.
also im looking at a truss for the front and rear diff housing and also bigger diff axles.
last step will be ARB winch bar. also tree sliders and bally bash plates.
later on down the road ARB locker for the DANA 35 and external roll cage.
You might need a new rear differential other than D35c rather soon after 33s.
TJ wrote:You might need a new rear differential other than D35c rather soon after 33s.
I was thinking the same thing...
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Eat, Sleep, Jeep...
ill see how it goings whats rong with the d35 ?
4x4part wrote:ill see how it goings whats rong with the d35 ?
the words "weak as piss" come to mind
yeah yeah..........use it brake it throw another in there ,,cheap as ....ya gonna lock it at some stage anyways......had 33s on my old xj sweet as ..then again i drive like a nana......
v8 tj...luvs the gas......
yea thats what i was thinking
Beats me why they hae a fixed c/a for 3-6.5 inches of lift. By that rationale the stock one should be able to go to 3.5 inches. = FOLD UP and/or ROOTED BUSHES!!!! (seen it and done it)
Adjustables are the only way to go.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
One of the main problems with c-clip design (which D35c is) that if the clip or axle breaks, there is nothing there to keep the tyre attached to the hub. You cannot drive anywhere.
xj wrote:Beats me why they hae a fixed c/a for 3-6.5 inches of lift. By that rationale the stock one should be able to go to 3.5 inches. = FOLD UP and/or ROOTED BUSHES!!!! (seen it and done it)
worried if it works it works i got the fixed ones because i don't have to stuff around. the way i see it if the stock ones are fixed it shouldn't mater if the bushes get rooted il just bye more lol
TJ wrote:One of the main problems with c-clip design (which D35c is) that if the clip or axle breaks, there is nothing there to keep the tyre attached to the hub. You cannot drive anywhere.
yea i no what you mean but it will just have to do for now
4x4part wrote:yea i no what you mean but it will just have to do for now
Agree with that logic. I just didn't want you to spend money on re-gearing and locker to find out later that it was wasted. If you do come across a wrecked TJ, you can take the rear Dana 44 (most export ones do) and mod it to work with XJ. They are the same width and stud pattern.
TJ wrote:4x4part wrote:yea i no what you mean but it will just have to do for now
thanks man il look at it i can get all the kit to swap it
