80 series window
firestonecruiser
80 series window
Post by firestonecruiser »
wanting a 80 series window motor for the drivers door.
cheers jono
hippy_
Re: 80 series window
Post by hippy_ »
Hey Dude, do a search on it, there a couple of threads on here about it.
http://www.offroadexpress.co.nz/Forums/ ... 22&t=34102
a80crewza
Post by a80crewza »
I've got problems with a window in my 80 as well :shock: . Been reading thru this http://forum.ih8mud.com/80-series-tech/ ... -pics.html May be alot cheaper than new motor if thats the problem..
firestonecruiser
luxsurf wrote:I've got problems with a window in my 80 as well :shock: . Been reading thru this http://forum.ih8mud.com/80-series-tech/ ... -pics.html May be alot cheaper than new motor if thats the problem..
mine is the same. i have read the link, only prob is kids like having the window down in the rear. i have checked with toyota and left read window motor from ln130 surf the same. i have a surf one so going to swap internals over as brushes in the surf one stuffed.
firestonecruiser
pulled window motor out n old ln130 motor filled with water. pulled the internal gearing out n swapped it over into the 80 series one. the old 80 one was slogged out in the casing causing the plastic cog to wear unevenly. once the internals swapped over i now have a mint working window.
a80crewza
Post by a80crewza »
Going to get mine done too. Did you just replace the plastic internal gear? Or did you replace more internals?
So the rear left ln130 motor works with the drivers door? Do you know if that means then that the rear right motor works for the passenger door etc :?:
firestonecruiser
yes it should they work opposite. all i did was remove the gold coloured cap. remove circlip. all gearing comes out.inside u will see if the steel shaft of cog that drives the window reg has slogged out the capping that covers white plastic gear cog, mine had, so just swap it all out. if u go to the link that hippy put up all info on there or google window motor for 80 series. i found a list of all motors that will work.
strx7
Post by strx7 »
if you keep killing window reg motors, buy a new window channel rubber (the piece the glass slides up and down in) in the past 4 years i've been through 4 RF reg motors (just as well they dont cost me anything) finally brought a new channel rubber for both front doors, my god what a difference, the glass slides effortless up and down now. They are approx $150 but well worth the money.
Flannel
Post by Flannel »
strx7 wrote:They are approx $150 but well worth the money.
Did you buy from Toyota or aftermarket?
strx7
Post by strx7 »
genuine toyota
Return to “Toyota”
