Hi guys,
I've seen these mentioned quite a bit on the Aussie forums. Apparently improve response and economy bit and stop the fouling up of the intake manifold. Does anyone know where I can buy them in NZ? Cheers
Egr Block off plate for GQ TD42
- the quadfather
- Bush Crasher
Re: Egr Block off plate for GQ TD42
it takes 5 minutes with a drill and hack saw to make one.
Gardengnome
- Truck Hore
If you're chucking the EGR gear.
Cut the flanges off, weld them shut and bolt them back on. Cheap and easy.
