Clutch plate replacement help toyota surf
Hay all im in need of changing clutch as warn out but want to learn to do it.
is there anyone here that would be able to help me out and teach me the ins and out happy to pay cash but just wand help. so if you have the time to change clutch and teach me would be stoked it a 91 surf 2.4 as ive just moved to welly dont have access to a workshop but have basic tools with me. thanks for your time
rob
rob
Re: Clutch plate replacement help toyota surf
have you got the replacement parts sorted?
do you know if it still has original clutch?
if you replace it with original dual mass type clutch its something like $2k for the clutch set. cheaper and more reliable to convert it to single mass. need hilux flywheel and a different pressure plate. specs are on surf site.
Yea clutch set up is standerd havent got any replacement parts yet was going to replace with the same as is there
stackd wrote:Yea clutch set up is standerd havent got any replacement parts yet was going to replace with the same as is there
So whats recomended as a replacement
tweake wrote: cheaper and more reliable to convert it to single mass. need hilux flywheel and a different pressure plate. specs are on surf site.
Did they all come out with dual mass on the 2.4s? I'm sure there was factory solid flywheel ones.
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
Roenut wrote:Did they all come out with dual mass on the 2.4s? I'm sure there was factory solid flywheel ones.
all 2lt are dual mass afaik. but i think 2l are single mass but clutch is a bit of a different size.
when i build the old surf 2lt motor out someone had fitted what i think is a 2l clutch setup. but there was a mismatch in size and it was stuffed.
tweake wrote:...original dual mass type clutch its something like $2k for the clutch set
luckyme wrote:tweake wrote:...original dual mass type clutch its something like $2k for the clutch set
wow... feel lucky now that never had issues with clutch on my surf. whats in that 2k?
Cover, plate, release bearing and a fookin expensive new dual mass flywheel.
Dual mass flywheels are non serviceable items (cant machine/rebuild them)
Thanks for the advice doing a single mass convy $1200 fitted so not to bad
only thing is sometimes they make a bit more noise and vibration at idle.
the dual mass is there to dampen noise and vibration.
Well had single mass done cost was $890 cheaper than first quote not bad on noise but seems lighter on the clutch pedal don't have to stomp on it 10 points for handling works great an heaps of grab
they got the engage height about right? ie you don't have to push it right to the floor?
