Right,
Some photos to show what I'm thinking.
This is the clearance under the rear wheel with the shocks disconnected, and the rear spring which is being extended, clamped in place with a hose clamp. Its just shy of 600mm.
This is the rear spring being extended with the hose clamp holding it in place.
And this is how much longer the shocks need to be. Another 50mm
And I have 100mm before the shocks bottom out. So the 50mm longer shocks will still have 50mm before bottoming out.
The shocks will get a bit twisted at the top. But I think its acceptable and shouldn't cause the shocks to fail.
Then I thought if I disconnected the front shocks, I might get some more drop out of the front suspension. But nope, it has bound up, mainly due to the castor correction bushes.
The spring is still firmly seated.
So I'm thinking spring retainers in the rear, with 50mm longer shocks but keep the same shock mounting bracket.
In the front, 6degrees castor corrected radius arms, or relocate front diff radius arm mounts and use standard radius arms. Then re-evaluate if spring retainers or relocation cones will be beneficial in the front.
