Removed the front seats out of the Lux and tightened up the loose bolts that were letting the backs move around and repaired the seat position slide mechanism, removed rear door cards and got the central locking freed up. Must be worth heaps more now
29th - 30th
- catalystracing
29th - 30th
Ill get this one underway..
Re: 29th - 30th
Having not really done anything on my own Zuk for a while I spent the avo finishing stripping the chassis off. Old one is now out side and new LWB chassis is now in the shed, upside down
but in the shed.
More work on Darinz new Nissan tomorrow, Taupo 1000 is coming fast.
Oh get my new dimple dies tomorrow, think the mate that made them has a few extra sets to, if anyone wants some.
Re: 29th - 30th
Removed the electric winch and support plate off the playdoh... Raised the front 10mm.. whoot whoot...
And back down to one battery.. Pinched one to put in the little 121 as its blew all its acid out....The 121 starts really fast now !
Re: 29th - 30th
pulled gearbox out. getting ready to rebuild it and fix up the mistake i made with the clutch last time.
Re: 29th - 30th
Went to start the terrano to do some firewood, wouldnt start.
Quick though was to bang starter, which was the problem.
Major problem is that i had to do that every time i turned the key....
Also got to drive a david brown 950, about a 50's tractor to move a log, so much fun starting up a old tractor thats been sitting for a few years. went well after it started, apart from the sparks out the exhaust......
muddyplumber
- Spring Free
Re: 29th - 30th
Got a pair of 80 series locked diffs that will find there way under the Mitzi
Re: 29th - 30th
Installed a 20inch LED bar
Its really bright!
Drove to Taranaki from Auckland to drop a container off..
http://i1195.photobucket.com/albums/aa3 ... F8F3CF.jpg
Its was cold
Bought another dog
Sunday is install 50mm lift and pull motor from race car... Fun fun...
Its really bright!
Its was cold
Bought another dog
Hugo -02102470477
Re: 29th - 30th
What sort of $ would he be looking at for them??
If you cant beat us Gingers, JOIN US!!
Re: 29th - 30th
semi 4x4 related.
recycled some landcruiser parts to make a hose reel for outside my shed.used a bj40 swinging spare wheel carrier and a damaged 16inch rim i was going to scrap.now i won't trip over the bloody thing!
Re: 29th - 30th
went for another play in waimake and spent a bita time trckking around godly head
Re: 29th - 30th
went for a trip on my dads place in Kaiwaka, was good times
Lubrication Specialist
Lubrication Engineers
- Crash bandicoot
Re: 29th - 30th
Installed the dual battery system in the mistral, hard wired the A/C pump to a dash switch and plumbed up to the engine breather for oily air and converted fire extinguisher for a reservoir
- jonossiksilvia
Re: 29th - 30th
Went for a easy play at the waimak today with a mate. First hole ended up with both of us winching out. No action shots as to busy driving. Heres a pic
- Suza
Re: 29th - 30th
Used the Safari to clear to 4x4 utes from a MVC I attended this morning on a one way bridge, bit of dragging, bit of winching and then a bit of big ditch verge 4x4 action
Re: 29th - 30th
Finally got the shita out of the shed. Took it to work with the aim of changing ova the steering box and a whole list of other things. Then got called out to a Scania set up for water cutting that had flat bats on its pump motor, that wasted about two hours. Spent the rest of the day wrestling the steering box out of the lada. Really hope I Neva have to do that in the bush...ever...
.I did read somewhere on here it was a mission, can safely say now I believe it.
Re: 29th - 30th
Went and shot some fuggin ducks up Waiarapa for last day of season. Pheasants, quails & canada geese now on to be shot and eaten list.
Re: 29th - 30th
Colinl wrote:Went and shot some fuggin ducks up Waiarapa for last day of season. Pheasants, quails & canada geese now on to be shot and eaten list.
Did that involve four wheeling? Otherwise its off topic here.
Re: 29th - 30th
Picked up a 20L of 15-40 for the terrano/bighorn for $104 from repco,
Seems like a good buy considering a 10L is usually about $95.
Also got some brake fluid and some rain-ex anti fog aswell, works bloody wonders.
Also fixed aircon unit, blown fuse aswell as another which i still cant figure out what it was too. (the glory of owning a jap import)
jimichelle
- Bush Crasher
Re: 29th - 30th
how does the break fluid work?
you apply liberally until it breaks? or just smear it on?
Re: 29th - 30th
saw red mu tonight 33'' or 35 maxiss mudzillas no lift fa guard cleance
Re: 29th - 30th
jimichelle wrote:how does the break fluid work?
Re: 29th - 30th
It was early and i hadnt had my cup of coffee yet lol
Re: 29th - 30th
Replaced the Swaybar link and D bushes with OEM rubber ones (corners a fair bit better now). Cleaned up the links and changed the engine oil while I was at it.
Ordered a 3" Exhaust and the last few bits for my Front Axle rebuild including the later 80 series CV's and flanges.
Tested out the rear cargo Mudgrabba mat by taking the dogs out in it, carpet stayed clean but everything else still filthy.
Re: 29th - 30th
50mm lift all round now. Front ended up been like 70-80mm haha now i just need some 35"s
Hugo -02102470477
Re: 29th - 30th
Friday night, replaced broken spring,
Drove up the back of possum palace, forgot diff lock, switched it on and speared off the track to rest drivers door on a tree
Now it matchs the passengers one
Going for the "hourglass" look
All going well until Sunday lunch time, when on a steep climb got a little air time with turbo fully spooled, and broke the shaft when it came down
Anyone know of any standard TD27 turbos, going cheap? That was my last one
Need to find one in next week or so.
datsunsafari
Re: 29th - 30th
farkinhell simon might have to ditch the terrano and get yourself a bulldozer or a tank.............or a safari
any pics of the latest panel damage.i don't know who's winning the "wreck my truck"compition you or caleb?seems to be too close to call
