I want to make the shackle more solid to keep both sides parallel.I have seen other people put a bolt through the centre of the shackle with a crush tube. Or a bit of box section with flats on it that is bolted as well. I don't want to weld a section in the middle as it's nice to be able to separate the shackle when changing bushes.
From factory they are a press fit onto a spline on the pin. I was thinking the whole job might be a bit easier if I was just to weld the pin to the shackle at 90 deg and be done with it. Any thoughts?
