7mge -----> Surf
Jafa
7mge -----> Surf
Post by Jafa »
Well its been such a long time since I spent any time on the old forums, but I think I'm back ...again... :oops: Been so busy at work, just had no time. average 75 hrs per week for that last year or so! :shock: Finally got a "boy" to train up so my workload should be much lighter now....hopefully.
Anyways things have changed around here too I see....not many of the old crew left on ORE now..!? Whats happened to Steve? I miss his SAS everything attitude!
I have just stared to get busy in the shed again, picked up an '84 Surf nice and cheap but has a dirty ole 3Y in it, so whats a man to do?...stuff the 7mge I had lying around that was going to be my winch challenge engine, into it and plop the 1UZFE into the race truck, with the intention of using the Surf as a tow wagon for the winch truck, sounds like a plan to me!!
Here goes!
The new Surf
The bad ole 3y 2 litre petrol lump
out she comes
In with a new heart!
More pics to come. O yeah, Bruce Hughes' 2005 bodied Prado/Surf/cruiser is up here at Autokraft for a couple of weeks so I'm gonna shoot down tomorrow and get a pile of pics
021 273 9942
jafa@inspire.net.nz
De-Ranged
Post by De-Ranged »
welcome back
Hey did you ever finish the last beast ??
Cheers Reece
Jafa
Post by Jafa »
:oops: thats still a work in progress :roll: I'll get stuck in straight after the surf is running and certed. Be nice to have the winch truck finished for Whakatane challenge in May I think it is
021 273 9942
jafa@inspire.net.nz
De-Ranged
Post by De-Ranged »
:lol: :lol: your as bad as me... I'm seriously looking at doing a few things to the rover just cause its going and the lemon is still a fair way off :roll:
Cheers Reece
mroffroader
Post by mroffroader »
:shock: that fills a bit of space :shock: how much HP does that produce :shock:
Jafa
Post by Jafa »
mroffroader wrote::shock: that fills a bit of space :shock: how much HP does that produce :shock:
:lol: yer it just fits
5M-GE, 2.7L, 143 HP@5200, 154 Ft-Lbs@4400
7M-GE, 3.0L, 199 HP@6000, 188 Ft-Lbs@3600
7M-GTE,3.0L, 232 HP@5600, 254 Ft-Lbs@3200, 5ps
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
Well i missed Bruce's truck :twisted:
Got the engine mounts done
I was a little worried about the lack of room between the steering box and the pwr steer pulley, but a shorter pwr steer belt helped that
A few pics of the new radiator cross member and fan mount/shroud
Also a shot of the clutch slave cyl, which is a 2L diesel one and the hardline is the 3Y one I think
The remote pwr steer reservoir mounted on the inner guard and plumbed in using various 2L,3Y and 7M lines. Had to get a new high pressure side line from pump to steering box made up :(
Left to do,
Fuel lines and pump
Air box
Relocate Battery
Clutch line from master cyl to slave
Top radiator hose
Electrical
My brother is a auto sparky and he's coming down from Napier next weekend so we should have it running next sat :wink:
021 273 9942
jafa@inspire.net.nz
mroffroader
nice progress man keep us posted i wana start up vid with no exhuast on :twisted: 8)
bigstu
Post by bigstu »
hi im wanting to put a 5mge into my yn60 do the factory mounts fit if moved or do new ones need to be fabricated?
Jafa
Post by Jafa »
If it had a 3Y then it need new ones made, puts the motor too high if you just move the factory ones, if it had a 2L diesel they will be ok.....I think
021 273 9942
jafa@inspire.net.nz
bigstu
Post by bigstu »
would a bodylift fix this?
Jafa
Post by Jafa »
yep probably have to be 50mm or so tho just from memory
021 273 9942
jafa@inspire.net.nz
NuTTa
Post by NuTTa »
you'd need to lift 50mm anyway if it's a diesel, then the bonet will shut without making a hole in the bonet, the diesel mounts do not have to be changed.
Brendon
monaro427
Post by monaro427 »
you don't have to if it is a diesel, my bonnet closed easy no body lift at all, i only did the body lift later, got to admit it was not that much clearence but it did close
NuTTa
Post by NuTTa »
On my LN65 i had to lift it, the bonet wouldnt close at all, did you lift the gearbox at all.?. that would prob give it enough clearance for the bonet to close.
Brendon
bigstu
5mge
Post by bigstu »
Am picking up engine 2moro just wondering how many people it wud take to lift it?
Mattman
Post by Mattman »
Nice conversion.
What radiator and fan have you gone with?
Matt
Jafa
Post by Jafa »
Mattman wrote:Nice conversion.
Matt
Thanks Matt, I have used a recored 2L diesel rad and an electric 16" Wiseco fan off Tardme.
Some more pics of the finished article, off to the exhaust guy tomorrow, just a bit of tidying up in the wiring area and in the dash to be done.
My brother the auto spark working his magic :lol:
I'm glad he knows what he's doin :shock:
Ready for the exhaust man
Just enough room between rad and pulleys, mite put some button head screws on the water pump pulley just to be sure
Little bit o tidying up and shes done, off to the cert man.... :roll:
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
o yeah and I will post a vid of the startup tomorrow...its on my home pc...only dialup :oops: :twisted:
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
021 273 9942
jafa@inspire.net.nz
niblik
Post by niblik »
very nice sounding start up jafa.. sweet work..
well done!!!
so now what?
:D
mroffroader
mean! that is 1 smooth engine 8)
FUBAR_nz
Post by FUBAR_nz »
Surf would have been all done ecept i/we had to repair some dodgy wiring like the start wire from ign switch in a space of 100mm had 4 diff wires with strip connector and 2 twist and tape, fix head light wiring, and wire up 4wd to dash that surf didnt have. and some other stuff
Had missing plug from ecu that made it more interesting and with 4 diff wiring diagrams not one was right, now i have decided to rewire the left gaurd to ecu,fuel pump,fan,headlights :D
just for bit more work :roll: all going well she will be all finished from my side sat avo
David
Jafa
Post by Jafa »
Does anyone have the 22 pin ECU plug for a 7mge (cressida) they can part with?, I need one to finish off my conversion
021 273 9942
jafa@inspire.net.nz
FUBAR_nz
Post by FUBAR_nz »
found plug from a 3sfe i think it was
Jafa
Post by Jafa »
Ok, Ive worked out how much this exercise has cost me and a list of parts I used so others who want to do this will know what they are in for. Bear in mind I didn't try to do this on a tight budget, so you could save a bit on some cheaper/second hand parts.
Engine (1990 7mge) $600
New pwr steer hose $150
Pwr Steer belt $18
Alternator belt $20
Radiator Recore $220
Electric Fan $80
Davies Craig Fan controller $90
Top Rad Hose (Maxima) $32
Battery (NS70L) $90
Simota Pod Filter $97
Spark Plugs $36
Oil & Pwr Steer Fluid $60
Fuel Hoses and Fittings $120
Clutch line $12
Certification $400 :evil:
Exhaust $380
Supra Clutch $80
Parts Total--- $2511
This does not include doing the head gasket "just incase",or my autosparkies time, or my own labor
Here's a list of secondhand bits I used
2L diesel Fuel hard lines
2L diesel engine mounts
5M upper engine mounts
5M Supra Flywheel,Bell housing
2L diesel clutch slave cyl
2L diesel radiator
Bosch Fuel Pump (044)
But the end result is a Surf that goes great and is far more enjoyable to drive. I highly recommend this swap if your 3y or 2L has shit itself.
The whole conversion was surprisingly easy, and once done looks like it was in there from factory.
021 273 9942
jafa@inspire.net.nz
mike
Last minute Mike
Post by mike »
Or a poxy 1kz :evil:
Thats what i like to hear. Could very well be on the cards for my surf!
Where did you sourse the engine from?
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
Jafa
Post by Jafa »
mike wrote:Thats what i like to hear. Could very well be on the cards for my surf!
Mike
Hi Mike,
Mike Holland (Suprasurf) hooked me up with it, one of his mates in ChCH was going to do the same swap but did a 1UZFE instead I think. I reakon a Turbo 7m would be easier to find (out of a Turbo Supra, and probably easier to get a manual setup for it too). Or mebbe buy a whole Cressida with a 7mge is an option too, you get ALL the wiring, fuel pump,sensors,plugs,ecu blah blah.
Your Surf is IFS?, you need a 50mm lift I think, not sure on that tho.
Its a greeat conversion tho, and flew through cert, no worries. Mechanically the swap is easy, paerticularly if you have the "rare as hens teeth" 5M belhousing, electrically its a bit of a mission if like me you know nothing about wires, but my brother said if he did another one it would be untold quicker. At the end of the day there is only about six wires you have to hook up and it goes.
Drop me a line if ya want to know anymore
PS..thats a great avatar :lol:
021 273 9942
jafa@inspire.net.nz
FUBAR_nz
Post by FUBAR_nz »
Ill post up a wiring diagram from ecu plugs as that is where we did conversion from
There will be a cressida up here in napier for sale soon,once ive sorted wiring for a RX7 batman out complete car auto with a 5m in it, no idea on $$ yet
De-Ranged
Post by De-Ranged »
Hey David you looking at parting out the bits on that :twisted: I want an auto and bits to run it.... thinking about running an auto in my Lux :wink:
Cheers Reece
