Hi,
What are the best defender replacement hinges to get? Doors are sagging and letting water through, finger size gaps. i have tried to realign them to no success.
Leaking Defender doors
Re: Leaking Defender doors
cheep ones from litpigzuk
http://www.landroverspares.co.nz/
Probably just britpart ones, that's what I got and they were OK, but OEM ones are probably a bit better and tighter. Have you posted your about your landy yet? Be interesting to see it
i thought it was normal for landrover doors to leak
my 4wd is not a truck
nakimud wrote:Probably just britpart ones, that's what I got and they were OK, but OEM ones are probably a bit better and tighter. Have you posted your about your landy yet? Be interesting to see it
Www.landroverspares.co.nz can get you what ever you want.
If you want to go with OEM, then just ask for them, if you want the bingy aftermarket cast alloy ones, just ask.
They can get you what ever you, they have pallets of goodness coming in from the UK all the time
