Suzuki+SR20DET+Hilux Axels+coils+Exo Cage
Mattrade
Re: Suzuki+SR20DET+Hilux Axels+coils+Exo Cage
Post by Mattrade »
Oil pick up.
Mattrade
Post by Mattrade »
Internal baffle plate and drain plug. Have i done this right ???? Any thoughts would be appreciated :!:
tomsoffroad
Flopsie
Post by tomsoffroad »
Nice work 8)
SMOKEY
Post by SMOKEY »
That Baffle will work fine for keeping the oil around the pick up, the other reason for baffles and windage trays is to keep the crankshaft out of the oil, I don't know if this is a problem in your application. Keep up the good work and thanks for sharing.
FITZY.
Mattrade
Post by Mattrade »
Made some windage trays for the back of the crank. thanks Smokey 8)
shortylux
Post by shortylux »
tomsoffroad wrote:Nice work 8)
X2
wayfastwhitee
Post by wayfastwhitee »
Them welds don't look like they'll be cracking anytime soon :twisted: :twisted:
bang-thud-thump
Post by bang-thud-thump »
Impressive.
Making stuff that pretty much works is not always the hard part.
Making stuff that really works and looks this good is another story.
Keep the posts coming.
Mattrade
Post by Mattrade »
Hi thanks guys :) Got some more done and got the engine sitting much better lower position. Had to cut out a bit of the gear box tunel to fit.
Mattrade
Post by Mattrade »
Bought some goodies.
3 inch flexy and Coby muffler
Changed my gear box mount to miss front drive shaft and on the left to fit my massive exaust=D
Mattrade
Post by Mattrade »
Engine mounts
Upper control arm comes up real high in the engine bay so stock mount hit.
So made my own out of some 6mm plate, to miss control arm and also steering shaft.
All welded and painted
Had to cut left mount closer to engine. now next problem is turbo actuator hits shock mount.
Antoni
Post by Antoni »
Nice truck mate, I'm a few years behind you trying to get a 4age and hilux axles in mine. I don't know what welder you are using, assuming an inverted tig, if so try turning the frequency up on your fillet welds it will narrow the arc up and concentrate it in the corner you can also play around with the balance and go more electrode negative if the material is clean. I'd like to dry sump mine but those pumps are anything but cheap I had considered making one but I dont know if Id trust it.
Mattrade
Post by Mattrade »
Hi Antoni, been following your build looks wicked 8) Going to be solid once done. Thanks ya ill give it a go, watched heaps of youtube videos on tig welding, now that i got the basics i can start playing with the million settings :roll:
Mattrade
Post by Mattrade »
Clutch, gear shifter, sorted.
3 inch flowmaster muffler
Made a ally plate to strengthen fire wall, and a few more to step it out a bit.
s15 master cylander
s15 master cylander
Looks a bit crazy but works. Going to make a bit of ally to cover it all.
Mattrade
Post by Mattrade »
Cuting up the front clip.
Mattrade
Post by Mattrade »
Finally got to the fun part of the project 8)
Made a bracket from the chassi to hold up radiator and intercooler.
Started on a 3 inch down pipe.
Mattrade
Post by Mattrade »
Relocated alternator and power steering pump.
Made a bracket to bolt the back exhaust to end of gear box then flexi joint to join to rest of exhaust just waiting for exhaust gasket to finish off the rest.
alternator mounted in its new location on the opposite side as factory up as high as possible
Power steer tucked up the only  place I could find,  hope it has enough clearance when the engine flexes on its mounts
Primed with crc zink it.
Then crc black zink it.
rob-mu
Post by rob-mu »
Great product that zinc it stuff though I'm sure it recommends applying a primer ontop of the zinc it before top coat
Mattrade
Post by Mattrade »
Chop rotate and tig back on.
Mattrade
Post by Mattrade »
Exhaust.
Hangers made from some 10mm bent rod
all done with 6 hangers and finished with some header paint
tomsoffroad
Flopsie
Nice work dude 8)
Mattrade
Post by Mattrade »
Re did my clutch set up. There was not enough leverage having it so low on the pivot. :roll:
Mattrade
Post by Mattrade »
Time for a test drive :D
Had my engineer turn this up for me and flair the ends of my inter cooler piping. Real good job and only 30 bux.
All running on stock loom draped over everything. Sounds mint, one very happy man
Mattrade
Post by Mattrade »
tow99
Post by tow99 »
mate thats awesome really gets up and goes!you must be stoked with getting it driveable
rob-mu
Post by rob-mu »
So sick man love the sound of the sr
Great work
hitbiga
Post by hitbiga »
Nice work, are you running the standard suzuki transfer case behind the sr20?
Mattrade
Post by Mattrade »
Hey thanks all :D
Yup standard transfer case with a full custom cradle. So hope it stands up to the punishment. If not will have to come up with a new plan.
Mattrade
Post by Mattrade »
Started to extend hood but half way through, realised that all the lines on the hood would be skew. so decided to re skin the hole thing.
attempt 1
attempt 1
Using my new laser, to square it up, was just keen to have a play with it
Mattrade
Post by Mattrade »
New skin.
