GME Extension Speaker
vvilly
Post by vvilly »
Hey all just wanna pick a few of you electrical guru's brains
whats the difference between these two
SPK04 - 4 Ohm Extension Speaker Box
4 Ohm Extension Speaker Box with Lead and Plug
Features
High performance elliptical 4 Ohm nominal 3 Watts maximum 5 Watts
SPK07-Dust/Water Resistant Extension Speaker
Dust/Water Resistant Extension Speaker with Lead and Plug.
Features
8 Ohms Nominal 2 Watts maximum 3 Watts dust/water resistant speaker
i know the more watts the louder it is depending on amplifier etc but Ohms???
What's your thoughts on the better speaker
Jase
jonossiksilvia
Re: GME Extension Speaker
Post by jonossiksilvia »
Fyi im using the spk45b speaker with my tx3100 and it goes good, clear and loud
tomsoffroad
Flopsie
Post by tomsoffroad »
Get a hearing aid :lol: :lol:
vvilly
Post by vvilly »
tomsoffroad wrote:Get a hearing aid :lol: :lol:
Sorry Tom i couldnt hear you over the Banjos
Henry
Post by Henry »
Hi
what are you going to use this for?
Henry
vvilly
Post by vvilly »
use it in conjunction with my tx3100
danielbeek
Post by danielbeek »
The 4 ohm will be louder at the same volume settings - it will draw more power from the radio.
The key thing is to find out if your specific radio is happy driving a 4 ohm speaker. If not, it may be fine for a while, but could overheat if used for an extended period. Some amp ICs are only stable with 8 ohm load.
Speaker sensitivity is very significant. Your dealing with naff all watts - for example a 4ohm 93db speaker will make more sound than a 4ohm 87db speaker, even if the 87db speaker has double the power handling. Every 3db increase in volume requires double the amp power, so an 87db speaker is starting on the back foot in a big way. The low wattage radio amp may not have enough output to match the more sensitive speaker before the sound starts distorting.
You could always wire your CB speaker output to one of your stereos door speakers (4ohm), and put in a change-over switch. Cheaper and probably sound better than those nasty little extension speakers.
vvilly
Post by vvilly »
i was thinking about wiring it up to my rear door speakers but am going with the idea of fitting a extension speaker by the centre map light on the truck (behind the head of driver and passenger)
catalystracing
Post by catalystracing »
As danielbeek said, check the rating of the radio for what ohms it can handle and go with that, saves letting smoke out of the unit :shock:
I have a suitable input on my car stereo, (3.5mm plug) so run an extension to reach, works a treat, and don't have to worry about where to mount the extra speaker. :D
vvilly
Post by vvilly »
Audio Power 3 Watts average into 4 Ohms
Audio Signal to Noise > 45 dB
i think thats what ya meaning??
the 3.5 jack is that the same as the one in top middle???
but if im plugged into that can i still listen to radio???
KIWI_TERRANO
Post by KIWI_TERRANO »
If you plug into head unit you can only here it whdn you put stereo on aux setting jase
vvilly
Post by vvilly »
Thanks
danielbeek
Nope - Audio signal-to-noise is something else, that's to do with the radio. sensitivity is a rating for the speaker. Looked on GME site and looks like they don't give that rating anyway, so moot point.
That close to your ear should make it irrelevant which is louder. Should be clear as.
You might want to use a line level converter if you wire the amplified output of the radio in to the Aux (low level) input of the head unit. Like the Fusion HL-O2: http://www.fusionelectronics.co.nz/car/ ... ries/hl-02
Cheap as, and could prevent damage to Aux in.
Got me thinking... the slickest would be to use cellphone car kit input (if present - so many radios now just have bluetooth), which would automatically put CB on to all speakers when a trigger signal is received.
...but not entirely straightforward, unless CB also has an output for this sort of thing.
vvilly wrote:Audio Power 3 Watts average into 4 Ohms
tycho
Post by tycho »
Weird that they do two different resistance speakers. Do they both have a 3.5mm plug to fit the TX3100? I got a $10 remote speaker from Jaycar. Now also used as a mount for the Ultraguage by pointing it straight up :)
evolution02
Post by evolution02 »
I have a TX3100 in the same spot in my surf but mounted with speaker facing down and find the inbuilt speaker loud enough unless the radio is up to much
vvilly
Post by vvilly »
i plugged the AUX through to the stereo today works a treat, but as what was said it can only run through AUX
so still going to go with a external speaker
mbw
Post by mbw »
I bought an old nokia hands free kit (non bluetooth) on tardeme and used the speaker from that, plug n play, works a treat. I think it cost me $6 including postage.
vvilly
Post by vvilly »
mbw wrote:I bought an old nokia hands free kit (non bluetooth) on tardeme and used the speaker from that, plug n play, works a treat. I think it cost me $6 including postage.
good score
Return to “Tool Shed”
