wanting to upgrade the bulbs in my 80 series. what is the maximum i can go to with out burning out the crappy factory headlight wiring loom.
cheers jono
bulb upgrade in 80 series
- firestonecruiser
Re: bulb upgrade in 80 series
Get the arctic blue? +100 or what ever they are, I have them in mine and they are choice.
- firestonecruiser
is that the 95/100 bulbs
na will be like http://www.narva.com.au/documents/item/45
still the 60/55w but brighter than standard without the excessive heat and current draw of a 100/90w
i put the plus 100 in my surf, and where a upgrade, a whiter light and brighter.
- firestonecruiser
skidmark wrote:na will be like http://www.narva.com.au/documents/item/45
cheers for that. thats what i was wanting to know.
cheers jono
Either buy a headlight relay loom kit, or make it up yourself than you can run higher wattage bulbs and not melt the factory wiring.
The +90 or +100 bulbs do put out better light than the std bulbs.
- firestonecruiser
have gone with the narva +100 bulbs and so far a big difference even with the headlights tinted. glad i get trade at repco
