Hey all
After going though the search on here I cant find any info on were to get shims for a d21 lsd.
Can any one help?
LSD Shims?
- Crash bandicoot
Re: LSD Shims?
need the diff code off the build plate
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=25&t=15427&start=0&view=print
Re: LSD Shims?
Ha ha ha cant do that...
Mine didnt have a LSD from factory.
I put one in....
1992 d21 if that helps any one?
I put one in....
- safaripete
Re: LSD Shims?
come for drive to palmy i'll shim it up for you nice n tight
Re: LSD Shims?
safaripete wrote:come for drive to palmy i'll shim it up for you nice n tight
I knew you would pop up!!! Nothing beats a true welded locker!!!
Wana weld a winch onto it for me at the same time
Re: LSD Shims?
Internal shims, clutch plates etc are interchangeable between most 4wd Nissan diffs. So if you can't find any Navara shims Safari or Terrano ones should fit. One extra each side and it will almost feel like it is locked - my truck doesn't feel like there is any give till you are going about 30 - 40kph on tarseal.
