It is quite easy to get 50%-110%, but to achieve your range would take some "Reece" thinking
Its not a project.... honest lol
Re: Its not a project.... honest lol
I figured you were playing with something along those lines when you stated earlier that you had AS adjustment from 29% - 110%.
- tomsoffroad
- Flopsie
Very goodly. Watching with much interest
Run into a clearance issue with the springs ment I've had to move my lower mount
it has helped in one aspect its steepened the dropping Anti-Squat it now drops faster but its narrowed the AS ratings 39,56,61,75,82 and 94
To give you an idea of the drop in rate on the 82% setting at full extention on the suspension (9") changes to 29%
Does anti squat and all the cad figures even matter if it never leaves the shed haha
Shut up in the cheap seats you Aussy...
Been working on the springs really getting over the smell of rust dust and I've only done one spring
Here's what I started with a standard HD landy spring
Cut the center pin and only the bottom leaf came off belted the crap out of it nope nothing
so ended up cutting the small bit of pin sticking then belting the crap out of the leaf till it finally moved then start again with the next one
Then flap the rust off and decided to taper the ends of the springs, since the spring is going to travel further than standard (15") I didn't want stress points where the leaves finish
Some of you might remember a thread a little bit longer than a while ago I did about Leaf springs, figured I had to have a go as one of the suggestions
One blister later from using tin snips to cut the 3mm UHMPE
I've cut the spring to about 3/4 the length of the standard but I'm 1/4 eliptical and with the plastic... I took an educated guess as to spring rate (number and length of the leaves)
Here's the test
its just taken the weight at 100mm of travel so I'm guessing I'm not going to be far off the mark of 150mm travel once I add all the bits back onto the back of the chassis
I also got the tank dry from the POR15 pre-treatment so painted the tank sealer
Now just need to finish the CAD work on the spring mount and I'll make that tomorrow
Here's the test
- skid
- Tyre Man
GotFlex wrote:Does anti squat and all the cad figures even matter if it never leaves the shed haha
wheres the multiple like button when ya need it
never a truer word spoken
- tomsoffroad
- Flopsie
1/4 elliptical
That's some crazy shit right there
Are you going to use standard type shackle bushes at the diff or get creative? Or is that a silly question
Im just using cheap shackle bushes. They work sweet, but don't last long for some reason
If you were any good at trials I've got a pretty cool toy for sale
Haven't made my mind up on the shackles yet, since I'm running 15" shocks I'm going to get alot of twist, working on the idea of a twist shackle
Just hung up on tieing the lower front arm mounts into the clamp block for the springs to improve its strength (and cool factor
didn't they stop using cart springs when henry ford was born?
- skid
- Tyre Man
De-Ranged wrote:skid shame you don't live closer I could build you a flash toy
If you were any good at trials I've got a pretty cool toy for saleI'll even finish it for ya for free since your a good bastard
maaaaaate, you would not believe the thoughts I've had about that particular trials truck
if only my lotto tickets worked the way I envision them working
you see that skiddy he put old in front of bastard
- skid
- Tyre Man
reddog40 wrote:you see that skiddy he put old in front of bastard
Yer. Toddy must told him about you
Yep the old ideas are the best I won't mention your still using something designed back in the stone age
Sounds like your tickets are as productive as mine
Sad thing is the toy might be parted out yet got one guy keen as but doesn't have the money so looking at options at this stage... hopefully
skid wrote:De-Ranged wrote:skid shame you don't live closer I could build you a flash toy
where did you get the uhmpe?
looks like a good alternative to coating the springs in chain lube once a week.
I have some new lr springs to dismantle it would seem
There's a plastics fab company just down the road from me they make the big fish tanks like Kelly Tarltons, they have alsorts of stuff in stock
Had a friend there yrs ago who used to take home off cuts, but having bought it before for jobs I'd say your looking at $150 for enough to do front and rear springs
Most tool and bearing shops can get it in cut to order
ludowici (spelling) plastics in Chch. they happy to freight it anywhere.
http://www.mulfordengineering.com/
so its uhmwpe?
Yep, I did go in and talk to the guys at classic plastics they recomended a different product called Nyloil but at $300 for enough to do my springs I figured I'd have a go with UHMWPE
Was talking with a mate of the Certifier over the weekend while he was in to do Nobbers truck, he was telling me there is a company that make a brand of springs called "Slipper springs" he has them fitted to his tuder hotrod, recon'd the plastic is the same just alot thinner.... possibly as thin as 1.5mm don't know if I'd go that thin but I'd try 2mm
cheers fella i'll investigate further as factory springs are a little archaic in function and pretty limited for flex in standard form,
did you remove a couple leaves as well?
Yep removed one main and two of the shorter ones and I'll possibly shorten another main... but I'm 1/4 elliptical so don't think mine is a good indicator of how to (I'll hopefully have some pic's up tonight to show what I'm up to)
Reading build threads from the UK seems to be remove 3 to 4 leaves from the standard pack witch would work well with the U bolts if you put 3mm thick plastic strips in
Didn't quite go the way I wanted today
of all the luck I've got two 5" grinders both of them wore out the brushes today
the second one just before 5
Anyway this is part of what I've been playing with
The lower link at the chassis, there is more to tie in... that was what I was working on
- tomsoffroad
- Flopsie
Didn't quite go the way I wanted todayof all the luck I've got two 5" grinders both of them wore out the brushes today
Id say your drill press brushes copped a bit of wear too
Just a thought in the 1980s we used fit hiace rear springs straight into series 2 rovers . they used to work quite well and there were only 3 or 4 leaves .I don;t know if the later ones fit but it might give you more spring options at very little cost.
nick
nick
There is a local Landy that is running hilux rears out back with a pre-load torque arm, it goes incredibly well but the guy has spent over 20yrs working on it
Got one grinder up and running again so finished off the passanger lower link mount and the spring carrier
Now I've just got to do the other side
Still gonna be ready for the 10th dude?
I'll be there, the rear end will be done
I'll also be fixed, got the injection on on the 5th so hopefully I'll be all good too
tomsoffroad wrote:Didn't quite go the way I wanted todayof all the luck I've got two 5" grinders both of them wore out the brushes today
Id say your drill press brushes copped a bit of wear tooLooks good
Ahahaha. My thoughts exactly!
This could get interesting.... been doing a bit of reading on the english landy forums found an old thread about a PTO setup for the Rangy transfer cases that uses what looks like the dog clutch setup from the center diff lock and the front drive flange from another transfercase guy was looking at selling them so didn't post up too many details.... but there was a couple of pic's.... and I have two rangy gearbox's
might see if I can work out how it was done
Hi Reece,
Any chance of a link to the thread you found on the PTO set up?
It sounds very interesting in deed
I'll be watching this space
Brett
Brett
