outo to manul convertion on a terreno 2.7d
what does this take is it easy to convert an outo terreno to a manul
Re: outo to manul convertion on a terreno 2.7d
It is impossible
You can however convert a TERRANO from an AUTO to a MANUAL
Please tell us how
is that text speak or is your engrish seriously that bad?
does somebody know how its done or does no one know
School holidays are just about over
I will see less of the losers on here thanks
You will need a gearbox,pedal box, clutch master cylinder,metal lines and slave cylinder.clutch and flywheel and the flywheel bolts, centre console and gear lever boot.
And once you got all that its just a case of swapping it all over.
- Crash bandicoot
nizute wrote:You will need a gearbox,pedal box, clutch master cylinder,metal lines and slave cylinder.clutch and flywheel and the flywheel bolts, centre console and gear lever boot.
least we forget you may want to change the diff ratio's or your speedo will be out?...or change the speedo drive etc
you will also need the rear driveshaft (different spline count)
any reason you want to change?
ive owned 2 terranos
both manual and they rev quite high at 100km/h
plus they do bearings just as quick as autos stuff out
another d21 terrano
ex lancer build
ex lancer build
many thanks it seems to me not worth it
Thanks for wasting everyones time. I'm still trying to work out who you are and why your taking the piss
kbjj wrote:Thanks for wasting everyones time. I'm still trying to work out who you are and why your taking the piss
x2
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
I am not taking the piss just asked
I thought it was an easy convertion
like using a shift kit like on yank cars
is that not what this is all about ha ha ha
Then why change the auto to a manual?
Duh.
Duh.
philip121 wrote:I thought it was an easy convertion
Are you asking about taking an automatic gearbox out of your terrano and replacing it with a manual gearbox, or are you asking about changing your automatic so it is manual shifting?
It's just more fun in a lada !!
manual shifting
I was never any good at school
he he looked out the window
