wanted suzuki carb
For all Suzuki related topics
jervisad
wanted suzuki carb
Post by jervisad »
anybody got a carb for an 8 valve 1600?
3.5Pajero
Re: wanted suzuki carb
Post by 3.5Pajero »
Hey yeah I might have, I brought a box of bits off a guy a while back and he reckoned the carby was off a 1600 he put in his samurai - will you recognise it if I post up some pics?
jervisad
Post by jervisad »
yeah i should do that would be good thanks if its the right one how much would yaa want for it?
3.5Pajero
Post by 3.5Pajero »
Hey sorry ran out of time to head out to the shed and get some pics last night but I will after work today.
As far as payment goes, if you have a spare suzi 8 valve 1.3 carby lying around we could do a swap?
jervisad
Post by jervisad »
thats allgoods mate umm naa i dont sorry ae i bought the truck and it had this motor in it so how much would you want and what sort of codishion is it in ??
3.5Pajero
Post by 3.5Pajero »
Here's a few pic's, looks like it's been sitting around for a while...
It looks very similar to the one on my 1.3, I was thinking if it fits I could throw it on and see if it does what it's supposed to, I'm guessing if it needs a rebuild would probably be easier for you to source one locally off a working engine?
jervisad
Post by jervisad »
yeah that looks the same as mine :) i think they are same ae but wasnt to sure haha, if you could that would be awesome thanks just to confirm it will be better than the one i have
3.5Pajero
Post by 3.5Pajero »
Hey sorry for the delay - So I swapped the carbs over and couldnt get it going, bumped into the guy I got it off and now he's 99% sure it was off his old 1300! Sorry to stuff you around - but all the best with finding one.
jervisad
Post by jervisad »
oh naa thats sweet as mate cheers anyways :D
jervisad
Post by jervisad »
does anyone know if they are the same carb? the 1300 and 1600??
zukmeista
Post by zukmeista »
No they are different. You could run a 1300 carb on a 1600 but you would need to put bigger jets in it.
jervisad
Post by jervisad »
oh true that cause i think mine has a 1300 carb because it looks the same as the one in the pictures above cheers
jervisad
Post by jervisad »
so what i was thinking was get another 1300 carb and then swap the jets over because they are much easyier to find than 1600 ones would this work??
zukmeista
Post by zukmeista »
Yep the jets are easy as to change, I would swap the secondary jet into the primary hole and then fit a 140 to the secondary hole. You need to either find a carby specialist or go wrecker hunting to find the different jet. The jets are inside the float bowl and you can get to them by removing the bolts the blue arrows point to in the below pics, they are screwed in and you use a flathead screwdriver to unscrew them. The jets have the size stamped in them on the head so it's not hard to tell which is which. And yes I have done this, it worked great on my 1600, the plugs were the perfect colour.
jervisad
Post by jervisad »
oh yeahp cheers for the help mate have had it apart before to see if it was just dirty inside but yeah its abit more than that, idk why or how but it looks to me like the butterfly valves are worn out like you can see gaps down the sides, and its sucking in to much air and choking out the engine
zukmeista
Post by zukmeista »
Get some start ya bastard or similar and spray it around the carby, when the revs go up that is where it's leaking air in.
jervisad
Post by jervisad »
yeah ive done that ae and it did so i sealed all the gaskets with gasket goo but it was still dieing, so i sprayed it in the carb with the butterflie closed and it reved up, also i was talking to a guy and he said that hes got a carb off a mitsubshi from picka part and hes had it on there for 5 or so years and hasnt had any trouble with it
zukmeista
Post by zukmeista »
Yep you can fit carbys from different models as well here is a howto on fitting a Toyota carby, they have used a 3k but a 4k would be better suited and they are EVERYWHERE! :D
http://www.acksfaq.com/toycarbinstall.htm
jervisad
Post by jervisad »
yeah that would bee cool but apparently the one this guy has just bolts straight on to the 1600 same bolt pattern and stuff
zukmeista
Post by zukmeista »
The 4K carbys are the same bolt pattern.
jervisad
Post by jervisad »
oh mint might have to try that :D
Return to “Suzuki”
