diahatsu rugger parts
dvkmunta1kzsurf
Post by dvkmunta1kzsurf »
diahatsu rugger wreaking. i have two im wreaking
BROWN RUGGER early 80s model
#body is full of rust.
#has good diffs
#has good transfer case
#gear box is a bit sad. will not change down from 3rd to 2nd
#motor runs sweet. its a 2.7 turbo diesel.
#has a slippy clutch and lost all brakes
offers on all parts or buy it as a hole
BLUE RUGGER late 80s model with square headlights
#no motor or box
#has diffs
#tidy body
offers on all parts
ASK what you are after on 027 7516240
brown rugger
brown rugger
Mehrts
Re: diahatsu rugger parts
Post by Mehrts »
What part of the country are you based?
Edit - see you're in Dannevirke.
How many Ks has the brown one done?
Toyhatsu Bitsalux
sig
Jeep Jeep
Post by sig »
has taz01 got in touch yet :D he was looking for rugger parts
crazyclark31
Post by crazyclark31 »
that gearbox on the brown one maybe ok. On mine the nylon bush the gear lever sat in fell apart which stopped it from changing from 1st to 2nd and from 3rd to 2nd. Replaced it and was sweet as.
Mehrts
Post by Mehrts »
Could also be that the big nut on the output shaft has loosened off causing shifting issues with second gear. Quite a common fault and a major pain in the ass when the shaft breaks while sorting it out (as I found out).
Toyhatsu Bitsalux
dvkmunta1kzsurf
yep taz gave me a ring the other day to sort out parts he wants. cheers guys for the info will look into that gearbox problem :D. will take some more photos in the weekend and will check ks on brown rugger and post up
zukmeista
Post by zukmeista »
crazyclark31 wrote:that gearbox on the brown one maybe ok. On mine the nylon bush the gear lever sat in fell apart which stopped it from changing from 1st to 2nd and from 3rd to 2nd. Replaced it and was sweet as.
Where did you get a new bush from?
crazyclark31
didn't. Took pieces out and used it as is. Worked sweet as. Guy I sold it to had no issues with it either till he blew transfer case apart.
dvkmunta1kzsurf
down rugger has done 97000ks
dvkmunta1kzsurf
pic of motor
dvkmunta1kzsurf
other body blue one
dvkmunta1kzsurf
rear of blue one
zukmeista
Post by zukmeista »
How much do you want for the whole brown one?
dvkmunta1kzsurf
after 1000 bucks as is cheers
