kzn130 knock
brakes-shocks-lockers-etc
dutchy
kzn130 knock
Post by dutchy »
Hi guys,
Done a couple searches but didnt find much related to my prob.
I have a knock on the front right, happens when ever i go over a bump. 50km/h in the dry seems to be the optimum.
i have replaced the bottom ball joint on both sides as they were worn and also replaced the disc rotors (pulled entire hub assembly apart)
Neither front wheels have any movement in them.
any ideas?
Chris
Surf - 50mm lift, front bar, integrated winch etc
contactable on 0220901730
BigSkellsy
Re: kzn130 knock
Post by BigSkellsy »
You might find your answer here.
http://www.toyotasurf.asn.au/forum
Konev
Re: kzn130 knock
Post by Konev »
swaybar bushes and links all good? bit of movement might create a knocking noise.
dutchy
Re: kzn130 knock
Post by dutchy »
BigSkellsy wrote:You might find your answer here.
did a couple searches, a lot of info but nothing that directly relates to my issue. but if anyone finds something please let me know. will create account and post after more searches, if the kiwi gurus cant pick it. (im sure you guys have it in you!)
Konev wrote:swaybar bushes and links all good? bit of movement might create a knocking noise.
I know my rear swaybar is missing a bracket (in process of replacing it) but that shouldn't sound like it is coming from the front? (it has a separate noise while flexing.... doesn't take much)
tweake
Re: kzn130 knock
Post by tweake »
also check body mounts.
dutchy
Re: kzn130 knock
Post by dutchy »
tweake wrote:also check body mounts.
added to list. thanks 8) any easy way to check them? (doing another big checklist this weekend)
tweake
Re: kzn130 knock
Post by tweake »
never checked the surf ones but have had trouble with nissans being loose before.
benorange
Re: kzn130 knock
Post by benorange »
did you find the knock? another silly thing to look at is if bumper is rubbing on front guard. found this on my old kzn130 after changing my bumper.
firestonecruiser
Re: kzn130 knock
Post by firestonecruiser »
shock mount bushes could be worth looking at
dutchy
Re: kzn130 knock
Post by dutchy »
benorange wrote:did you find the knock? another silly thing to look at is if bumper is rubbing on front guard. found this on my old kzn130 after changing my bumper.
all fixed and you were on the money 8) my winch moved the front bar a little and went all downhill from there. re adjust and tighten was all it needed
