td42 crankshaft oil seal gen or aftermarket
as above, need to replace mine whilst its on the floor and before i put a new clutch in.. the genuine seal is over $100+gst on its own without the aluminium housing from nissan... which is why i am tempted to find aftermarket alternative. anyone had and bad experiences?? its one of those jobs you only want to do once.....
Re: td42 crankshaft oil seal gen or aftermarket
I just did another one yesterday and just stock the aftermarkets ones there onyl 30 od bus , never had a problem with them measurements seem fine and they dont come with the housing ,
Hey
After market fine as long as you use quality bits,,, we use lots of Permaseal new zealad gaskets components good quality ...can buy these through repco etc if you have any dramas pm and will organise for you,,,,,,,,, front main seal part number NJ831N rear main seal NJ829N any worries pm me cheers
You must have gone to the wrong Nissan dealer. I got one for about $55 the other month from Nissan. It has been said before genuine seals are better but I've used aftermarket ones in diffs and various other places with no issues. Only when genuine for the rear main due to access being a major job, and hopefully they are worth the extra $$.
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
T-mo wrote:You must have gone to the wrong Nissan dealer. I got one for about $55 the other month from Nissan. It has been said before genuine seals are better but I've used aftermarket ones in diffs and various other places with no issues. Only when genuine for the rear main due to access being a major job, and hopefully they are worth the extra $$.
i would say so, actually got a genuine one for $57 inc..
- gary_in_nz
i picked up a crank seal from BNT this afternoon for $18, its only the rubber seal with the spring retainer, is this all I am after to do the seal? read somewhere that there is a metal shroud of some sort or can the new seal be installed into that?
I got quoted $97 from Nissan dealer in Hastings.
- mud_slinger
Try cockram Nissan in chch or gt Nissan in Wellington, I've dealt with them and have had some good pricing and service, normally parts from cockram are on your doorstep the morning after
needs more curry
0272593533
0272593533
I found Mayfield Motors (Blenheim) useful when looking for oddball parts, not that a rear main seal is odd. Good service and willing to ship parts. Forget the guys name I dealt with though..
North Shore Nissan (Takapuna) do some real sharp pricing normally too.
Tomo
I'm just going through this at the moment myself, the turbo models come with the alloy housing hence the price differences. So I've been told anyways.
Anywhooo back to it
Anywhooo back to it
gary_in_nz wrote:i picked up a crank seal from BNT this afternoon for $18, its only the rubber seal with the spring retainer, is this all I am after to do the seal? read somewhere that there is a metal shroud of some sort or can the new seal be installed into that?
That is a decent looking clutch alignment tool where did you get it?
those clutch alignment tools available on trade me for $10 bucks. i have just packed up my whole house ready to move overseas so i have no idea where mine is otherwise i would have given you it as i will never use it again.... they are plastic but work well.
http://www.trademe.co.nz/motors/car-par ... 101826.htm
Users browsing this forum: No registered users and 37 guests
