cheersssss
FJ40
FJ40
OK all you 40 gurus.. I need to know is the 70 series GB will bolt up? or did they do a split case xfer..? as Im sure you can pull the 4spd and bolt up the 5spd..???
cheersssss
cheersssss
- mudlva
Re: FJ40
only difference is the input shaft between the diesel and petrol
otherwise bell housing bolts are the same
the 5 speed is the same unit as the 4 with the over drive gear as a separate unit behind the main box for the over drive, this will make your drive shafts lengths wrong and will need alterating
pretty certain that all the 5 speeds were running the split transfer box, although i may be corrected
Re: FJ40
mudlva wrote:only difference is the input shaft between the diesel and petrol
X2
Re: FJ40
cheers guys..
new someone would know..
