350 Chev experts!
350 Chev experts!
Hi all. Wanting to sort out my engine. At the moment its a 350 that sounds cool but doesn't run that well. Not looking for big power but wouldn't mind a few more horses
. I'm just thinking a hotter cam, a new carb (currently running an old looking 4 barrel thing), msd ignition and then get it properly tuned. questions are what cam and what carb?!? then does anyone know some one palmy that has worked on a few of these? kruzin kustoms and hot rod heaven are the ones that come to mind but im sure there will be some mechanic who knows these engines inside out and could point me in the right direction.
- skid
- Tyre Man
Re: 350 Chev experts!
I would say that most mechanics would know a dirty ol tree fiddy inside out
ask around or wait long enough on here and someone will let ya know whos good and whos not
otherwise, I have heard that Roskilda isn't too bad
- Sadam_Husain
- Angry bird
chevrolux wrote: Wanting to sort out my engine. At the moment its a 350 that sounds cool but doesn't run that well.
If its not running that well you might want to start with bit of basic maintence and a tune before you throw a grand at a new carb and cam for it? Try giving the carb a good clean and new gaskets, sparkplugs, check leads, timing, exhaust/inlet leaks etc
- safaripete
i gave my 350 a good tune up (new leads plugs timing etc) and it runs a whole lot better
you can bring it round sometime and go over it if you like
Leads, plugs, carb clean, fuel filter. Do the basics then get it a tune, dont throw away money at a cam and a carb yet.
Cheers Daniel
Cheers Daniel
don't forget PCV on tappet cover as these are prone to clogging up and are often over looked. Tune ign timing by vacuum gauge as the harmonic balancer with the timing marks may have moved giving you a false timing light reading as the are getting to be an old motor now.check fuel pressure, if its a Holley carb then no more than 7 lbs pressure but better at 3 to 5 lbs. Fuel bowl heights are important on any carb.Leads, plugs, carb clean, fuel filter. Do the basics then get it a tune,
just a few small jobs can collectively make a hell of a difference
PS vacuum gauge can indicate the cam ( valve ) condition
Take it to marty jones, he is cheap and knows what he is doing
cheers boys! yea was gonna go over all the plugs and leads and stuff and give the carb a good going over. where is marty jones?
DJ wrote:don't forget PCV on tappet cover as these are prone to clogging up and are often over looked. Tune ign timing by vacuum gauge as the harmonic balancer with the timing marks may have moved giving you a false timing light reading as the are getting to be an old motor now.check fuel pressure, if its a Holley carb then no more than 7 lbs pressure but better at 3 to 5 lbs. Fuel bowl heights are important on any carb.
gday just wondering about how to time a 350 with a vac guage?
and how to find out more about checking your cam with a vac guage too
Dannz71 wrote:DJ wrote:don't forget PCV on tappet cover as these are prone to clogging up and are often over looked. Tune ign timing by vacuum gauge as the harmonic balancer with the timing marks may have moved giving you a false timing light reading as the are getting to be an old motor now.check fuel pressure, if its a Holley carb then no more than 7 lbs pressure but better at 3 to 5 lbs. Fuel bowl heights are important on any carb.
attach vac gauge to carburetor or a port that gives vac at idle, advance or retard the ign timing till you get max vac, then retard timing by 1" vac, and lock off.
pedro
Pedro
oh cheers
ya really do learn something new every day
Wow you do indeed
I know of using a vacuum gauge to check timing amoung other things (my old man used to have an old Gunsons one that was even labeled with common faults on the scale). But had never actually thought of setting the timing by vacuum. I've always done it by ear when I don't have a light handy
If you are going to set timing by vacuum only, then by all means follow this method
BUT do it at 2500-3000rpm with your vacuum advance can disconnected, as all your mechanical advance should be in play by these RPMs. And listen very carefully for knocking afterwards, particularly under load.
If it is a motor you want to last then invest in a timing light as knocking can be inaudible especially in a rattly 4x4 with a loud V8.
I would thoroughly recommend the following page for anyone new to playing with timing on a SBC as there is a bit more to it than setting idle advance and calling it good.
http://www.crankshaftcoalition.com/wiki/Hot_rodding_the_HEI_distributor
Pedro wrote:\
redz driver
Yip like the others have said to do the basics but include a compression test wet and dry and a leak down test on each cylinder as well just to get an idea whats going on inside
Real men drive swb leaf spring trucks
bang-thud-thump
I agree get a decent tune.
If you still want more look at the whole package ie the right carb on the right manifold, headers that suit your purpose etc
No point running mis-matched components and suffering a compromise for the sake of a few hundy as 350 bits are common as.
I assume a torque monster is what you want rather than dialing 9k on the tach?
