Quick Question on Which Transmission pipe is Which
For all Nissan related topics
travis2ninja
Post by travis2ninja »
I am wanting to install a trans temp gauge, which way does the fluid flow from?
Thanks
Crash bandicoot
Re: Very Quick Question on Which pipe Transmission pipe is W
Post by Crash bandicoot »
start her up and go for a drive one pipe will be hotter then the other.
klompy
Post by klompy »
In the past I have taken both hoses of an fitted hoses to each pipe and into seperate containers.Start your motor for a few seconds and turn it of.The rest is obvious.
travis2ninja
So i ended putting it on the first pipe.
And either it's on the wrong one or the gauge is wrong.
Stays around 60-62 Degrees all the time. And went up to 80 once when i was driving around with the torque converter unlocked.
What are your transmission temps?
fullthrottle
Shuttle Queen
Re: Quick Question on Which Transmission pipe is Which
Post by fullthrottle »
You want to connect it to the 2nd pipe as this is the oil outlet from the trans which will show the true oil temp as it exits the trans.
Return to “Nissan”
