Hi got a 3litre hilux just discovered that I have coolant leaking from under the dash on the passenger side.
No obvious hose issues under the bonnet so I can only assume that its under the dash. Can anyone shed some possibble light on what I should be looking for?
Coolant in hilux cabin
Re: Coolant in hilux cabin
Heater core is leaking or the pipes that run to it thru the fire wall....
Yes done some more reserch since posting and I came to same conclusion.
looks like a pain in the arse to get it out. Am selling the car so its a bastard of a time for it to happen.
Had a go at pulling the heater core out got dash off but what a pain....decided to bypass it asI am in a warm climate and heaters are not used that much.
Just wondering whether running some of the copper particle based radiator repair fluid through it may be an option.....I have had it work on a holed rad ??
any opinions?//
any opinions?//
What brand did you use....and was it a heater core leak or radiator leak
grytvikken wrote:What brand did you use....and was it a heater core leak or radiator leak
was the heater core mate ..bars stop leak ,worked well for a year sold truck was still doing job then ....
heater core outta old jeep , 3 bolts line up right behind engine so yeah bar leaks for the win in my case
v8 tj...luvs the gas......
Thanks mate I have used that product its pretty good hey
