Hub spring
Danjr
Hub spring
Post by Danjr »
After a hub spring for Asin hilux/landcruiser free wheel hubs. I've snapped mine. Hopefully someone has one floating around there workshop?
Dan
evilknieval69
Re: Hub spring
Post by evilknieval69 »
If you have no luck I'm sure I could find a Nissan one at work on Monday. dunno if they're the same though.
Keep it in mind, I'm in tga.
oldblue
Re: Hub spring
Post by oldblue »
Are there 2 springs, which spring are you after? I've got the large springs from electric hubs, should fit.
Danjr
Re: Hub spring
Post by Danjr »
G'day, Just the one large spring I think? Cheers Dan
oldblue
Re: Hub spring
Post by oldblue »
PM me if you want it, only got the large springs. Cheers
Return to “Toyota”
