landcruiser hub parts needed asap
You Get That
Post by You Get That »
My kzj78 decided it would make a mess of its front wheel bearing and completely bugger everything inside. i can get bearings rotors ect from parts store but I'm looking for the main nut that holds everything in and the electric hub bit that has the copper windings around it.
Addicted to suzukis....
sig
Jeep Jeep
Re: landcruiser hub parts needed asap
Post by sig »
i have a complete pair i want to move on but freight would be a killer
try oldblue
oldblue
Post by oldblue »
Got one or two, are you still running electric hubs if so you would need a good slip ring, if manual I also have a good slip ring but damaged coppers on it.
You Get That
Getting it sorted thanks to oldblue. on a related note where do people buy fron wheel bearing/seal kits from? Ripco quoted me 290$ a side
tallsam66
Post by tallsam66 »
Try BnT ..should be way cheaper
sig
Jeep Jeep
Post by sig »
i put new kits thru my playdoh when i did it . a mate at extreme sorted me for about 60 bucks a corner from memory
