Hilux surf with safari rear springs?
Camfitz30
Post by Camfitz30 »
I'm wanting to lift my surf on a budget and fix the tail sag lol, and I heard that fitting safari springs is like having a 2 inch lift kit? Is that true or is the any other trucks springs will do the same job?
80serieslandy
Re: Hilux surf with safari rear springs?
Post by 80serieslandy »
Camfitz30 wrote:I'm wanting to lift my surf on a budget and fix the tail sag lol, and I heard that fitting safari springs is like having a 2 inch lift kit? Is that true or is the any other trucks springs will do the same job?
i think 80 series cruiser standard springs lift up the surf's saggy bum. but could imagine it might give it a stiff ride seeing as the cruisers are alot heavier..
tomsoffroad
Flopsie
Post by tomsoffroad »
80 Series cruiser is what you want. Factory saggy ones will lift your Surf a couple of inches. New standard height 80 series will give you about 4-5" lift. Im assuming yours is a 130 Surf?
Camfitz30
Post by Camfitz30 »
tomsoffroad wrote:80 Series cruiser is what you want. Factory saggy ones will lift your Surf a couple of inches. New standard height 80 series will give you about 4-5" lift. Im assuming yours is a 130 Surf?
Mine is a 130 yes, but it would struggle to run heaps of lift on standard dampeners etc?
tomsoffroad
Flopsie
Probably will need new shocks. I'd be temped to unbolt the bottom shock mount and see where they sit with the 80 series coils first. You might get away with it but probably not :mrgreen:
stealth
Post by stealth »
Would the factory 80 series shocks fit the 130 chassis?
KIWI_TERRANO
Post by KIWI_TERRANO »
80 series rear spring and 80series factory height shocks fit surf
I have done it
stealth
Post by stealth »
Were you able to level out the front with justthe torsion bars? Aany problems you encounted?
KIWI_TERRANO
Had manual hubs so cvs werent always spining and bj spacers then did a sas
surfee
Post by surfee »
hi will springs and shocks fit in the rear of a kzn185?
Camfitz30
Post by Camfitz30 »
Not to sure about a 185 but they went straight into my 180 easy as
KIWI_TERRANO
surfee wrote:hi will springs and shocks fit in the rear of a kzn185?
I know springs are same sizing but don't no what lifts it will give and the shocks are different
surf93
Post by surf93 »
Hi mate I put 80 series springs in the rear of my 130. I have no issues what so ever. Springs dropped straight in.
Return to “Toyota”
