Can anyone explain what and how the Columbus compression ratio/capacity testing method is/works.
Google does not seem to recognize it (well for me it won't)
Columbus compression test method
4x4x4byfar
- Driver/Navigator
- Crash bandicoot
Re: Columbus compression test method
you mean the ability to calculate compression ratio based on engine capacity piston type, cylinder's etc etc?
4x4x4byfar
- Driver/Navigator
Question is, is the Columbus method just the term used to do the test (using information as above) or is it a particular type of test?
