LN65 2L-TE Conversion
gutless lux
Stropper
Post by gutless lux »
Hi all my 2l in my hilux has blowen the crank seal so insted of fixing it i am thinking of an upgrade. Iv found a 2l-te for 600 with no injector pump or alt, was thinking of using the injector pump off my current motor any ideas if it will work or even bolt up at all? The motor is out of a surf so i imagine it will just bolt straight in? Im a newby to Toyota's after recently migrating over from Isuzu and an sick of throwing money at this 2l just for something else to die on it.
Konev
Re: LN65 2L-TE Conversion
Post by Konev »
better option would be to get a re-conned 3L.
gutless lux
Stropper
on a tight budget and them 3l's arnt cheap so have decided to go this way instead, so just wanting to know more about what i need, what will and wont work for the 2L-TE
Mehrts
Post by Mehrts »
Injector pump off the turbo engine will have the boost compensator, whereas your N/A one will not have it. Doesn't mean you can't use it. It will just pump the diesel at the same rate when on/off boost. May be quite smoky when starting to drive off if you wind the fuel up to suit when on boost.
Toyhatsu Bitsalux
trucked
Post by trucked »
gutless lux wrote: was thinking of using the injector pump off my current motor any ideas if it will work or even bolt up at all?
Yes it will work, all the l series pumps are interchangeable. Not sure how well a 2l pump will stand up to a turbo though, may not flow enough fuel but i could be wrong
Mehrts wrote:Injector pump off the turbo engine will have the boost compensator, whereas your N/A one will not have it
I think you abit mixed up there the 2l-te doesn't have a compensator, its efi and controlled by the ecu.
Its the 2l-t that has the manual pump with boost compensator
Mehrts
Post by Mehrts »
Ah yea bugger. Missed that bit!
Toyhatsu Bitsalux
gutless lux
Stropper
so a 2l-t pump would be the way to go?
would the motor run rich when not on boost if the n/a pump was turned up to compensate?
Sorry for all the questions im new to desils lol
trucked
Post by trucked »
gutless lux wrote:so a 2l-t pump would be the way to go?
ideally yeah you would want a 2lt.pump, the tops of them are interchangeable so you could get the compensator from the 2lt and put it on your pump, only thing I'm not really sure about is if the 2l pump pump will flow enough(it's not a big thing as you can't lean out diesel like a petrol and cause damage it will just go slower). I'm not sure if the pump is different in that regard
and yes Merths answered your other question above
tweake
Post by tweake »
i would just fit the 2l pump and wind it up a tad.
just have to adjust your driving style so you don't put the boot hard into it from a stand still. when your driving around your on enough boost that a boost comp doesn't matter so much.
then you can save up for a much better engine.
gutless lux
Stropper
Well the motor got sold from under me but have found a 2lt outof a Toyota mark II for 800 witch includes everything. Much difference between this and a surf motor?
tweake
Post by tweake »
basically the same as surf engine.
there is also a performance version in some of the cars called a 2lt-he. rather rare.
but even the standard 2lt is a good deal. just be careful you don't get a 2lt-1. they are different to a 2lt-2 and 2lt-e.
trucked
Post by trucked »
tweake wrote:basically the same as surf engine.
only thing I can think of is the sump might be different as crown is rwd? and your 2l sump won't have the drain for the turbo.
gutless lux
Stropper
Welding nd cutting isnt a problem for the sump. i just dont wana buy something thats gona be more hassle than its worth. thanks for all the help aswell, think im finaly understanding a bit more about diesels :roll:
tweake
Post by tweake »
good point, i don't know if the the car is front or rear sump. but turbo drain is in the block not the sump. at worse its just a sump swap.
btw i'm assuming here that the original 2l is a 2l-2 not a 2l-1. 2l-1 has roller cam and different head. i'm not 100% on swapping a 2l-1 to a 2l-2.
Ant
Post by Ant »
92 LWB Safari TD42
Return to “Toyota”
