Just got it going , going out to woodhill this weekend to give it a proper try,just going up and down my driveway i saw just on 2Bar
Turbos are a T28 and a GT35
slide wrote:Sweet work! Did you do math to work out turbo sizes? Or just give it a guess and go for it?
Keen to see some videos of this weapon in action
klompy wrote:May be join a club and learn how to recover a vehicle safely before you injure some one or worse.
slidenyo wrote:what were the egts up to?
be interested to see how it go's and what it sounds like...
tweake wrote:what injection pump are you running?
bombaybasher wrote:tweake wrote:what injection pump are you running?
Stock non turbo pump with screw wound right up and an electric lift pump(mighty facet)
bombaybasher wrote:the only reason i could think of a snapped crank would be from high ks, too much timing,hammered bearings and lots of heat causing excessive knock-pretty much everything that my motor is going to get this weekend.
