WJ ABS light
Haggis
Newbie
Newbie
WJ ABS light
Post by Haggis »
Hey guys, got an issue with my abs light not going out and i wondered if anyone could shed a light on this for me. I have recently renewed the front brakes and cleaned up the rear and the light was not on then and everything looked ok, not long after this the light came on, i checked for fault codes on the dash but as far as i can see these codes don't cover ABS faults, can you retrieve abs codes from the vehicle or do you need the OBD11 scanner? cheers.
luckyme
Re: WJ ABS light
Post by luckyme »
Can be many things... dirty or faulty sensors, clock spring, brakes etc.
Take it to a mechanic or stealership, high end scanners can read the ABS codes.
Haggis
Newbie
Newbie
Re: WJ ABS light
Post by Haggis »
yup, thought it might come to that, thought i would ask though, thanks any way
safaripete
Re: WJ ABS light
Post by safaripete »
i had to get mine scanned and came back with a faulty wheel speed sensor
managed to pick one up off ebay for 70nzd to my door
Return to “Jeep”
