Failed Warrant - rear brakes
jagni401
Post by jagni401 »
I failed my warrant because the rear brakes are imbalanced. Do I need to bleed them or look at adjusting the rear shoes? Or are there other things to look at.
Truck is a doublecab hilux.
nizute
Re: Failed Warrant - rear brakes
Post by nizute »
Pull the drums off check that there is no leaks from wheel cylinders or axle seals, if all good then check operation by using two large screwdrivers on either side of the shoes and someone pushing slowly down on the pedal(make sure you do this one side at a time or you will pop the cylinders )
If everything is ok then clean and adjust.
tltourer
Post by tltourer »
If your injector pump is leaking, then the diesel can spray down to the rear drums contaminating the shoes on one side, thats what happened to my toyoace. I tried cleaning and sanding the surface but no improvement, in the end i swapped one of the contaminated shoes to the otherside to make them even and get my wof. obviously replacing all the shoes would have been the best thing to do :-)
Smurf
Post by Smurf »
tltourer wrote:If your injector pump is leaking, then the diesel can spray down to the rear drums contaminating the shoes on one side, thats what happened to my toyoace. I tried cleaning and sanding the surface but no improvement, in the end i swapped one of the contaminated shoes to the otherside to make them even and get my wof. obviously replacing all the shoes would have been the best thing to do :-)
Aye??
Injector pump being on the engine at the FRONT. Can spray diesel all the way to the BACK brakes??
Don't think so dude.
Henry
Post by Henry »
Hi
Most of your issues will be either a oil leak from the axle seals, leaking oil onto the break shoes. Or my experience with toyota rear drum breaks is a slave cylinder is seized. They really don't like water......
But as I play in water that means that I need to fix it.
Take off both rear drums and check for Oil. If no oil, check the slave cylinders. try pushing in both ends of each slave cylinder. you will find 1 is jammed. Just keep a eye on the level of brake fluid as you do this. It will go every where if you are not careful.
At that stage I go to safe'r' brakes in Chch and get a new slave cylinder.. Actually I replace both to try to keep things even...
Henry.
tallsam66
Post by tallsam66 »
Could also be unevenly adjusted.The shoes adjust each time you use handbrake (in theory) check the adjustor isnt seized or just full of crap.
tweake
Post by tweake »
Aye??
yes it can. had it on a hiace. the entire chassis/driveline was soaked and only noticed due to the pool of diesel under it when parked up.
Smurf
Post by Smurf »
tweake wrote:
Aye??
yeah I have had the same with a massive oil leak from my transfer case, but as you said, only all over the chassis rails and driveline etc. but from there it's not really going to get to the brakes shoe is it.
tweake
Post by tweake »
would be rare but not impossible.
but i think he would have noticed the pool of oil/fuel long ago ;)
more than likely its just one side is out of adjustment. the auto adjusters are temperamental.
bang-thud-thump
Post by bang-thud-thump »
Take it to a workshop if you need to ask here.
Its brakes. They are sort of important.
I saw enough screwed up home jobs when I was on the tools, not ideal Neil.
And no way did diesel get onto the rear brake shoes.
You would need to park in a diesel pool to get that effect.
Even front pads would take a shit load of diesel leaking down. You would crash from oily tyres first.
jagni401
Post by jagni401 »
Cheers guys, yep will strip the drums apart tonight and have a look, I did the rear bearings and axle seals not long ago but you never know.
jagni401
Post by jagni401 »
One of the rear wheel cylinders was seized so I replaced it, then bled the system, and re adjusted both brakes up - It is still imbalanced. Both brakes are clean and there are no leaks from the wheel cylinders or axle seals. Wondering if it is now worth putting new pads on and machining the drums? Would rather not go to this trouble, if this is not the issue, as the current pads are probably only half worn.
Could the rear proportioning valve have an influence on the breaking to the left and right side to the rear wheels, or is it purely affecting front to rear braking??
Cheers for your help guys
mudbugga
Post by mudbugga »
PV wouldn't affect the rear brakes side to side.
Try giving the shoes a scuff with emery cloth or sandpaper, and give the drums a real good scruff up with it as well. Could try swapping the drums left to right as well.
Adjust them up, then drive it hard to get them warm before putting it over the rollers again.
jagni401
Post by jagni401 »
Yea forgot to mention that I have scuffed the drums and pads up, then, swapped the drums over. I'm checking the brakes by putting the rear axle in the air and supporting it on jack stands, then putting it in low 1st and letting the wheels turn then apply the brakes. The left side is definitely stronger than the right side.
mudbugga
Post by mudbugga »
Ok. Try doing it on a shingle road or put it back over the rollers.
vvilly
Post by vvilly »
some times its just as easy to buy some new cylinders and it will free up the shoes a bit. at the same time do a full flush of your brake lines
jagni401
Post by jagni401 »
Here are a couple of pics of the side which is testing weaker. Do these pads look like they are wearing as they should? Not a lot of the surface seem sot contact the drum. This was after i sanded the pads and used the brakes for a short burst
Heath
Post by Heath »
What does the inside of the drum look like?
Put a straight edge on the braking surface and see if its got any channels or distortion.
Are both sides showing the same wear patterns?
If you swap the drums over does the wear pattern change to the good side?
redz driver
Post by redz driver »
Looks to me the best option is machining your drums and replacing the shoes I have wasted hours trying to get them even in the past. Your shoes have a section on glazing on them My 2 cents anyway
Real men drive swb leaf spring trucks
jagni401
Post by jagni401 »
Yea cheers guys. I might just get the drums machined; fit new shoes and start fresh.
tweake
Post by tweake »
if the hubs are worn it may pay to get good 2nd hand or new ones.
went through all that with one car. ended up replacing drums with 2nd hand ones which fixed it.
Tarmac
Post by Tarmac »
Looks like time for a disc conv... On my SJ it cost the grand total of around a hundy for 4x shoes and 2 new slave cyl's (freee drum skim) and then its all new . Hilux parts seem to be cheaper as more made etc... I see your in Chch - pm me if you want drums skimmed / limit checked
Return to “Toyota”
