Hi all,
Doing a rear disc conversion on my hilux.
After some calipers to suit, need ones that the handbrake can operate off of.
Hilux rear disc conversion
Re: Hilux rear disc conversion
a couple of options the easy way is to buy SNR kit and bolt on prado discs and Mr2 calipers but this can only be used on the wide axel diffs, I used discs and calipers of a early gen Pajero i had to make a bracket from 10mm plate and bolted to back of axel flange worked well and also on the narrow axel.
yea i got the widened diff in, and have prado discs, just looking for brakes to buy
