Hi All,
My S2a has a very rotten passengers door top. Sliders are totally gone and so is the metal under it. The sliding window is stopped by a screw cos if it slid open it would fall out!
So I need a replacement, doesn't need to be a minter. I don't mind adding a couple of patches but needs to be ok.
Don't need the glass. Just the frame and slider if poss.
Cheers and beers,
Muddymatt
WANTED - S2a L/H door top
muddymatt1973
Re: WANTED - S2a L/H door top
I know in the UK they make aluminium ones from a architectural profile.
i'd like a tad bigger windows.
might have to go see what is available down APL to make such a thing happen.
muddymatt1973
did you check out mamaku 4x4 or the one at pickapart in Tauranga?
muddymatt1973
I have checked out heaps on trade-me but no luck yet. One at a wreckers up here - already gone
Pulled it off the door today as it's going for a WOF soon - no door tops required for WOF so no questions about corrosion in them being within 30 cms of hinge area
Removed the glass and channels etc.... it's actually worse than I first thought!
Ah well the rest of the truck is coming together excellent
