Been asked to ask the question, not really interested as I don't own one
1991 if it matters
lilpigzuk wrote: Is there a fix other than buying genuine yota ones?
suzolla wrote:Yes it is quite common due to vibration as it is mounted directly to the inlet manifold. Seem to crack around the brackets.
Should either rubber mount or onto the body somewhere.
Tim
wjw wrote:suzolla wrote:Yes it is quite common due to vibration as it is mounted directly to the inlet manifold. Seem to crack around the brackets.
Tim
There is also a manufacturing fault with some of them, where by the top isn't crimped properly and leaks, easiest way to fix is to replace it
