hilux surf to hilux chassis swap questions
foreign
Post by foreign »
i have a surf right now on a hilux chassis. it has a lift on the springs and sits high enough to ride on 35s pretty easily. That one has a bunch of rust above the windshield. i also have a surf with a good body, ifs and a buggered motor. i want to take the good body and put it on the hilux chassis. anyone have any tips and maybe a link to where someone has done it before. while the bod is up i can fix the exhaust in a few spots and do the mods needed to the steering rod and a few other things.
any information or suggestions on the best way to lift the two bodys off would be appreciated.
Rob
hosehustler
Re: hilux surf to hilux chassis swap questions
Post by hosehustler »
what sort of hilux chassis is it on as there are several different lengths..... :?:
I hate signatures
foreign
Post by foreign »
im not sure of the exact model because i got the truck of someone else. he says its a mid 80s beam axle chassis. it currently needs the rear mounting brackets welded on.
De-Ranged
Post by De-Ranged »
I just did this on Nobbers build the hilux chassis was from a solid axle surf tho
this has caused a bit of an issue with LVVTA due to the chassis swop
shity old hilux
Post by shity old hilux »
Look on chassis rail by front right drivers wheel. Will b chassis number i have done a chassis swap b4. Would also help if stated the model of the surf.
J_Dub
Post by J_Dub »
Im confused.
If it already has a surf body on the hilux chassis then shouldnt it be just a straight swap? Your only replacing whats already there?
Smurf
Post by Smurf »
My guess.
you have a 2 door surf body with a fibreglass roof like this
or a 4 door body like this
Sitting on a solid axle surf chassis? Chassis number should start LN60 or Yn60
foreign
Post by foreign »
sso the full story. i got the truck of trademe and the guy told me that it was a surf on a hilux chassis. i was and still am in canada at the time of buying it so i didnt really look at it as well as i should off. lesson learnt i think. anyways the body seems to have a bit of rust all along the top of the windscreen and my old truck doesnt. the way its set up at the moment is that there need to be mounts welded on the chassis for the rear body to chassis mounts.
im thinking that the rust will be enough of an issue that i better to put the other body on it.
both bodys are 4 door models
IMG_4706 (2).jpg (26.79 KiB) Viewed 9430 times
shity old hilux
You also said u dont know how to lift off. When i done my chassis swap we jacked the body up high enough to get some big wooden beams between chassis and body then just got a few of the boys around and lifted the beams onto 44galion drums. Then we just rolled the chassis out from under the body. I managed to get the body high engouh to leave the engine on the chassis and swap to the new chassis once it was out .Have got pictures some where. Will try to dig them out for u if u like.
foreign
Post by foreign »
shity old hilux wrote:You also said u dont know how to lift off. When i done my chassis swap we jacked the body up high enough to get some big wooden beams between chassis and body then just got a few of the boys around and lifted the beams onto 44galion drums. Then we just rolled the chassis out from under the body. I managed to get the body high engouh to leave the engine on the chassis and swap to the new chassis once it was out .Have got pictures some where. Will try to dig them out for u if u like.
thats a great idea mate. i was trying to think of making a scaffold over the truck to put the winchs on and shit. would defiantly rather do that.was it hard to left. eg could two guys do it one end at a time.
shity old hilux
Id say a safe 2 people each side front or back first not the whole truck to get on top of the drums then we just went around putting 1 block undr each beam one at a time till we had the right hight
shity old hilux
Last edited by shity old hilux on Fri Oct 04, 2013 11:46 am, edited 2 times in total.
foreign
Post by foreign »
hey mate i cant view those pics as i guess im not your fb friend
shity old hilux
Knowlesie
Post by Knowlesie »
hosehustler wrote:what sort of hilux chassis is it on as there are several different lengths..... :?:
what hilux chassis fits up too kzn130 best ? thinking of doing the swap myself
Smurf
Post by Smurf »
LN or YN 60 is the best as the body is almost a straight swap, only need to move two body mounts to make the body fit, then just a case of making everything else fit in. gear levers, Radiator, engine, etc etc..
foreign
Post by foreign »
so almost back in nz and about to start this swap.
what all do i need to disconnect?
body bolts, wiring, streering, waterlines to heater/radiator, fuel lines where they connect to filter, break, clutch, accelerator cables
what else am i missing?
next question. while the body is off is there anything useful i can do to the chassis?
thanks for the input guys
bigstu
Post by bigstu »
Did you buy this of a young guy called ethan? Im sure I seen him selling it on trademe ages ago. As for what to disconnect basically everything that goes from body to chassis or viceversa you will soon find anything missed as you start to lift it, id look at setting up the rear mounts and painting the chassis under seal the body pretty much anything you can think of thats easy to do with body off, what motor is it running?
Thanks Stu
foreign
Post by foreign »
yup stu was of that guy. bit of a mistake on my part i think
stealth
Post by stealth »
does this need to be certed?
Mate has one that i looked at and I comtemplated getting it, as it looks like a bolt for bolt job has wof and reg, but no cert.
foreign
Post by foreign »
[quote="stealth"]does this need to be certed?
From what I understand it needs a cert cos the chasßis and body numbers would be different. I'm changing to high steer and RUF right now so will have to cert anyways.
Return to “Toyota”
