KZN130 squeak/rattle
hawiii
Post by hawiii »
Hey all,
I have a squeak/rattle that is coming from the back of my manual KZN130 surf. The truck has a 2" suspension lift, with raised coils and torsions wound up. This doesn't occur all the time, mainly when slowing down and when I'm off the accelerator. I don't think its my drive shaft as it was rebuilt at the start of the year. A mechanic I asked thought it was probably the trailing arm bushes, can any one give me any information on this? Or any other possible causes? Cheers
BlakeNZ
Re: KZN130 squeak/rattle
Post by BlakeNZ »
is it definitely suspension, as opposed to the rear door/window combination or the body mounts?
tallsam66
Post by tallsam66 »
Could be failed rear sway bar bushes or they might be real dry with having been in water alot.
Mine used to squeak alot so i put rubber grease on them .If they are slogged out they will clunk abit.
If you have done body lift check all the bolts are tight.
Could also be a loose shock.
Return to “Toyota”
