modified ln130 surf drives like a boat
- Stropper
hi guys
Iv just brought a 1992 toyota ln130 surf its had lots of modifications done to it by the last owner such as a 5mge 6cyl supra engine put in it, 3in body lift, possible suspention lift but not 100% sure,its had a solid front axle conversion out of a ln65 hilux, 33in mud tyres and lots of other things that go abit off subject.
driving this thing on the road is a nightmear it ducks and dives then pulls to the left then suddenly to the right etc you really got to hang on around corners aswel.
just wondering if anyone else has experienced this after modifcation like this its all been certified to be road legal except for the front axle conversion it must of been a after fort.
i was going to start with the simple and get a wheel alighment done. but fort id ask on here first if anyone has any ideas. the front axle looks to have been done properly but whos to say its not straight etc.
Any help will be awesome.
Re: modified ln130 surf drives like a boat
Sounds like the castor angle is wrong, but a angle meter on the top of the stering arm on the swivel hub idealy i should be 3-5 deg leaning back.
- tomsoffroad
- Flopsie
Definitely caster by the sounds of it. I set caster depending on the tyres the trucks running. For example, the 60 is set at 6deg to allow for the 37" crawlers. Something with less aggressive, smaller rubber you'll get away with less castor.
Interesting that it's certed and drives like a dog
Something must have been changed post cert?
throw a pic up ..chances are someone will know the truck....
v8 tj...luvs the gas......
- Stropper
its not certed for the solid axle conversion just the motor,body lift etc.
ill look into the caster angle for sure now.
ill try get a pic up soon looks a lil different now iv changed the wheels etc but sure someone will reconise it
Rear sway bar still fitted?
That can make a huge difference to body roll round corners if taken oiut.
Toyhatsu Bitsalux
- bob_or_jim
Deff look at castor and also look at the toe in. If it has too much then it is rather hard to hold straight. Also are the drag link and panard parallel. If there not then any little bump will make it wander.
- mudzuki
- Bush Crasher
I would be checking bump steer aswell
- mudlva
Sounds like the steering may of been the reason to sell it. Hopefully you have not bought a lemon here.
Where abouts are you as i reckon you need to take it to a auto engineer and get them to maybe write up a report to take it back to the previous owner and maybe look at some from of recourse or repair
- mike
- Last minute Mike
does it have an auto locker in the rear? They have their own little fun aspects to them as well, usually when on and off the gas into corners.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
- Stropper
hey guys thanks for all the ideas.
does anyone know of a good place in auckland that i could take it to let them look at it check wheel aliment, castor angle and just the general set up of it.
- hosehustler
Post pics of front suspension mountings, steering box, tie rod and drag link and you'll get all the advice on here, plenty here have done several SAS conversions and will share knowledge happily
I hate signatures
What part of auckland you in?
- Stropper
West auckland. glen eden.
Will try get pics up tomorrow tried taking some now but abit dark.
