1HDT Crankshaft wanted
Ben
Post by Ben »
My 1HDT has run a big end bearing and my crank is no good for the rebuild, so I'm looking for a replacement.
Would consider one that needs regrinding if anyone has one kicking round or knows of someone that might have one.
Ben
Trundle
Re: 1HDT Crankshaft wanted
Post by Trundle »
lineside 500 plus gst or new form toyota 1000 plus gst ,
Or a nissan td42 motor is 1000 complete. hehehe ,
Make sure you replace the rod bolts and you will have to get the rod resized ,
Also from memory you cant get oversized bearings ?
doddzee
Is Doddgee
Post by doddzee »
Ive got this sitting in wellington
It was rebuilt twice (poorly by a engine re conditioner in Wellington) then started excessively smoking at 130,000 km so it got pulled and replaced with a 24 Valve. Main bearings etc were all replaced at time of rebuild.
Ive taken the injector pump and turbo kit. Head, block, crankshaft etc all there. Will sell it for $500 and you will get a spare head.
MWB V8 Safari Ute
Ben
Post by Ben »
Trundle wrote:lineside 500 plus gst or new form toyota 1000 plus gst ,
Thanks. Lineside were out of stock when I called, and have drawn a few other blanks too. I was too scared to ring Toyota for a price!
ACL do undersize bearings in a few sizes. They have been low/out of stock but apparently have made more and they are on their way to NZ.
Ben
Post by Ben »
doddzee wrote:Ive got this sitting in wellington
Cheers, I'll shoot you a PM.
Ben
