If anyone can help I'd appreciate it..
churchill wrote:Hey man, with the way your supercharger is plumbed up it could be boosting at idle. I'm pretty sure in standard form they relief the boost at idle. Might be part of your problem.
churchill wrote:Asked and answered.
As an engineer I'd tend to place a MAP sensor as far away from the intake port as possible to help smooth out the signal. I'd also keep it away from the supercharger outlet for the same reason. I'd be looking at somewhere down the back of your supercharger/intake manifold mount plate. In all honesty I've never mounted one of these before and only owned one vehicle set up with a MAP so it's only an educated guess.
oldyella wrote:Yep, I had trouble with the ms2 on the lr due to the computer map signal teeing off the fuel pressure regulator vac line. Made a dedicated connection much better.
