Hilux rear driveshaft
brakes-shocks-lockers-etc
Steve_t647
Post by Steve_t647 »
Hi guys I have an odd one.
the centre bearing is failing on my hilux too quick, I have a judder in the driveline on take off but it goes away at road speed. :?
What I found was when I swapped the driveshaft with my parents the problem moved (and I had to swap it back), when I swaped it back the two shaft's were 90 deg out (one was turned 90 deg) I changed this and the problem went for a bit but now it is back. :(
H2OLOVA
Post by H2OLOVA »
Could either be an unbalanced driveshaft (from hitting rocks etc) or the universal joints at either end could be buggered :cry:
JTop
Post by JTop »
If your back springs are too flat the D/S is too straight which will contribute to early C/B failure
J Top
