Because of this I had to use a new pipe from the airbox to the turbo and had to remove the return hose from the tappet cover breather.
When we pulled the old airbox and hoses out it was noted that there was oil getting back into the turbo from the tappet breather. I elected to put my old oil catch can back on to alleviate this.
The black hose goes to the tappet breather and the blue one hangs loose.
Should I plumb the blue hose back into the outlet of the airbox as it was before,
as seen by the T on the old pipework, or leave it hanging? I do not want to risk water getting into it too.
This is where it could be plumbed back?
