Lada trails truck revisited
De-Ranged
Re: Lada trails truck revisited
Post by De-Ranged »
Well back into it part of the deal for the sale is I have to finish this to club running standard so starting with a shave n brace on the axles
hows this for a shave
Going to have another go at it tomorrow so more pic's to come
De-Ranged
Post by De-Ranged »
Rear axle done
More to come
madlux
Post by madlux »
De-Ranged wrote:Well back into it part of the deal for the sale is I have to finish this to club running standard so starting with a shave n brace on the axles
:shock: snug fit...
De-Ranged
Post by De-Ranged »
3mm clearance.... been doing em to that for yrs and haven't heard or seen a mark from where any diff has touched :wink: .... but that is 10mm that is bent in a press brake and welded with formed shape, it is going to take alot to bend it
Scruffy
Post by Scruffy »
I'd say there were Sherman tanks around with less bracing in the driveline than that!! Looks good mate, been reading your thread over the weekend, lot of time spent and a lot of very tidy engineering, very cool :)
De-Ranged
Post by De-Ranged »
:lol:
thank you
looking forward to finishing it
De-Ranged
Post by De-Ranged »
a wee update
finished the shave n brace on the rear axle
While I was at it I did the front one as well
Started on the winch mount... a cross brace to mount the back of it off
Then the hook mount for the front sections
Then the lower bar for the bumper to tie the two hook mounts together and tie into the winch mount
De-Ranged
Post by De-Ranged »
Winch mount done I've used the winch mount to tie in the bumper and hooks
Now to finish off the bar and start sorting the drivers corner panel work
1000dollamitzy
Post by 1000dollamitzy »
yay, looking good, cant wait to take this thing for a spin, not long to wait now, very happy customer :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
I dont have an attitude, I have a personality you can't handle....
De-Ranged
Post by De-Ranged »
Here is the finished bar.... yep this is all it needs
What you don't see (because they arn't there yet) is two bars that will tie in through where the indicators sat to the suspension strut brace... so they will triangulate the top corners.... adding anything more into this is just weight
Had quite a discussion with my shed mate over this "its not strong enough, needs braces..." lol na
De-Ranged
Post by De-Ranged »
Been busy with little bits that seem to take alot of time... like pulling the pedal box and brake master & booster etc
got the battery boxes sorted so that Rick can paint the back
Hopefully get the pedals mounted in soon and start on the bumps not looking forward to that one
De-Ranged
Post by De-Ranged »
A wee update still working on the toy
Since the bottom of the shorkle is way lower than the air box so Ive put a drain tap on there
You Get That
Post by You Get That »
any chance of some more pics of how the engine is mounted?
cheers if you can.
Addicted to suzukis....
De-Ranged
Post by De-Ranged »
Will do, going into the shed soon to do some more work on it
Been struggling with the front bump stop mounts, I never designed the guards to work with hyd bumps so it is a real tight squeeze lol
Just about got the passanger one sorted this shows how tigh, Im cutting through both sides of my moncoque guards to fit them... the bump cans will become structural
This is what I have to fit
After a bit of trimming
a bit of work on the bump can an some glue
all thats left is for the outer skin to be welded back on
De-Ranged
Post by De-Ranged »
Been a bit distracted with other things to update this, Im a bit past this point at the moment but the camera batteries died on me and I kept forgetting to charge them lol
the finished bump
and to fill a request
I have stood the motor more upright to help the drive shafts clear and to give me more room in the cab.... due to the front axle swing the sump is going to be replaced with a custom one to allow a full size drive shaft instead of a solid one
the word I got from some of the trials guys was that you don't want to go too far back it doesn't climb well, opinions differed about the ideal from crank pulley just behind the front axle centreline to the max of where I have it, the closer to the front the more it will limit suspension travel due to UJ angle range on the drive shafts and length of the shaft
Hope this helps
De-Ranged
Post by De-Ranged »
A wee bit of an update been doing lots of little things like extending the steering shaft for rick, trim on the bonnet and drivers guard, tiding up rust, made the bonnet pins, drivers bump stop can, work on the exhust etc
All things that arnt exciting lol but take time
Rad is in, after alot of talk it is going in the back.... Going to put a bulkhead up behind the seats and over the top of the rad... when Rick has the fuel tank installed
Sorted the trans cooler lines, this turned into a bugger of a job.... I didnt have any tools for this dia line and being this close to christmas there is no chance of getting in tools till in the new year, so.....
Another simple job that took all day :roll:
De-Ranged wrote:
Rad is in, after alot of talk it is going in the back.... :
No longer destined for an E Class truck then
De-Ranged
Post by De-Ranged »
Na just a club truck now.... the 35" claws sort of kick it out of class too :lol:
De-Ranged
Post by De-Ranged »
Console and engine cover frame, just a case of folding up the engine cover panels and screw them into the frame
De-Ranged
Post by De-Ranged »
Just about nailed the engine cover... been really enjoying this, I think I might have to do something like this in the landy
the rear has a cover to access the motor and trans and trans dipstick
Still got a bit to do on the drivers side gets a little funky to get the steering shaft through, Ive sorted my lines its just a case of building it
tomsoffroad
Flopsie
Post by tomsoffroad »
Shame the pics don't do it justice of just how much works go into projects like this. :D Looking good Reece 8) 8)
SupraLux
Complete Bastard
Post by SupraLux »
I'm having flashbacks to the movies of my youth... anyone ever see Battletruck? :lol:
De-Ranged
Post by De-Ranged »
tomsoffroad wrote:Shame the pics don't do it justice of just how much works go into projects like this. :D Looking good Reece 8) 8)
:lol: only people who have built something similar can grasp that
At the moment I just want it finished so I can work on a toy for me :lol:
And no talk of battle trucks :lol: rick is mad enough to try it.... I dont want it wrecked straight after Ive finished it......
1000dollamitzy
Ahhh come on, I'm not that bad :? :? , I only rolled my last truck 3 times in 12 months........Oh, ok maybe I am....anyone want to play chicken with my LADA :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
rokhound
Post by rokhound »
SupraLux wrote:I'm having flashbacks to the movies of my youth... anyone ever see Battletruck? :lol:
Geezus Steve, You are now showing what an old fark you are :lol: :lol: :lol:
De-Ranged
Post by De-Ranged »
Engine cover is done... didnt have the camera but its cool lol just got the rad bulkhead and the cab is done, thats waiting on rick to get the rad back in
Start on the brake pedal tomorrow
Was hoping to have this at a state to hand over to rick by the end of the yr but the log boats are putting the pain on me to do a boat in picton or nelson between christmas and new yr
this is going to have to wait till I get back... sorry
SupraLux
Complete Bastard
Post by SupraLux »
De-Ranged wrote:And no talk of battle trucks :lol: rick is mad enough to try it.... I dont want it wrecked straight after Ive finished it......
You think there is any chance this truck could be wrecked?!!?!?!??! :lol:
You obviously know what I'm talking about, which means you're of similar old-fark vintage :lol:
rokhound
Post by rokhound »
SupraLux wrote:You obviously know what I'm talking about, which means you're of similar old-fark vintage :lol:
hell yes. I went to see it at the savoy in town. It was a double feature with another NZ classic called "Wildman".
De-Ranged
Post by De-Ranged »
another wee bit done
and here it is with the bits bolted on
Now I'm in the process of making it fit into the lada at the right spot.... just a little massaging and it'll fit then its the throttle
rokhound
Post by rokhound »
There doesn't appear to be any danger that he'll turn the firewall inside out when he stomps on the brake pedal then Reece :mrgreen: (well not from the servo/pedal mount anyway)
